We´ll I am not seeing that much more on the Windows machine and the logging there does not show raw bytes there even if I run in debug mode.
I have also made sure to turn the wind sensor around to generate changing data and I have also moved around both temp sensors ch 1 and ch 2 to create changing temps and humidity but still no events in the Indigo log in debug mode.
I have included back the device into Indigo yesterday and run Z-Wave in debug mode for maaaany hours and the only raw bytes for node 213 (D5) I see in the Z-Wave log in debug mode are the following:
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 D5 06 31 05 01 22 00 ED DE
Z-Wave Debug . . requestVarSensorStatus: node 213, endpoint None, type 1, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 23.7 °C (float: 23.700000)
Z-Wave received "213 - Temp 1" sensor update to 23.7 °C
Strange that it first of all points to endpoint = None? According to the manual the temp for channel 1 should be endpoint 1.
Just to be sure I did a search for 01 0C 00 04 00 D5 in the whole log file but the only hits I get are the one I listed above.
I am including the full inclusing log from my Windows machine running Z-Way server and I am also including the inclusion long when including the device into Indigo.
If you search in the Z-Way server log for the text "error" you should be able to find the following strange Z-Wave error:
"Error returned from _zway_cc_call_handler(zway, cmd, node_id, data[3], length - 4, &data[4]): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)"-----
I don´t see them in the Indigo inclusion log though. Remember also that I am experiencing quite much syncing ("interview") problems in my Windows machine as well when I am trying to create the device in Z-Way Server on my Windows machine. This weather station ZMNHZD1 is indeed doing something strange/erroneous/odd.
I have attached the full inclusion log in debug mode for Indigo Domotics as well. (Device node id is 212 in this log while it is 213 in the log printout above.)
Looking in that log it does look like Indigo creates 10 endpoints when syncing in the device:
Z-Wave Syncing - retrieved multi-endpoint types: 1:(21 : 01), 2:(21 : 01), 3:(21 : 01), 4:(21 : 01), 5:(21 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01), 9:(21 : 01), 10:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 86 31 85 8E 59 80], 2:[5E 86 31 85 8E 59 80], 3:[5E 86 31 85 8E 59 80], 4:[5E 86 31 85 8E 59 80], 5:[5E 86 31 85 8E 59 80], 6:[5E 86 31 85 8E 59 80], 7:[5E 86 31 85 8E 59 80], 8:[5E 86 31 85 8E 59 80], 9:[5E 86 31 85 8E 59 80], 10:[5E 86 31 85 8E 59 80]
