I recently purchased the super small and cool temp and humidity sensor PAT02-B from Philio.
This is a Z-Wave PLUS compatible device and it is really cool and small.
Variations are PAT02-A and PAT02-C.
Tech info at http://philio-tech.com/products_sensors.htm and more details at http://philio-tech.com/products/PAT02-B.pdf.
User manual can be found at for example http://www.z-wave.pl/en_US/p/file/fa5b8 ... Manual.pdf
The user manual is valid for all three models.
Device syncs in nicely into Indigo but and I can adjust parameters via the Manual Parameter command.
I get battery status updates, temp updates and I can see that humidity value has been synced in but since Indigo seems to sync it in incorrectly the humidity value is not shown. Or in fact it now seems that it alternates between temp and humidity?
Here is the device log output:
Indigo Z-Wave Version: 1.0.365
Node ID: 140
Model: Multilevel Sensor (routing)
Model ID: 00020020
Manufacturer: Philio
Manufacturer ID: 013C
Protocol Version: 4.05
Application Version: 1.11
Model Definition Version: 0
Library Type: 3
Class Name: Multilevel Sensor (routing)
Class Hierarchy: 04 : 21 : 01
Command Class Base: 31
Command Versions: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 8Fv1 30v1 31v5 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 2, 3, 11, 14, 15, 66
Associations: 1:[1]
Config Values: - none -
I have also submitted a device request via the Indigo GUI.
