Is Zooz 4-in-1 Zwave Sensor supported?
Wed May 25, 2016 7:30 pm
noefresh offline
Got this because it's small and offers temp/motion sensing. Getting the feeling it's not supported though. Here's the log dump:
May 25, 2016, 6:28:02 PM
  Z-Wave                          Indigo Device "Zooz 4-1" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.365
Node ID: 14
Model: Routing Slave
Model ID: 20212101
Manufacturer: Vision / Yale
Manufacturer ID: 0109
Protocol Version: 4.05
Application Version: 5.01
Model Definition Version: 0
Library Type: 3
Class Name: Routing Slave
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 2
Associations: 1:[1]
Config Values: - none -
Wed May 25, 2016 7:40 pm
Re: Is Zooz 4-in-1 Zwave Sensor supported?
I hadn't heard of that one before. Do you have any links to documentation / manuals for it? I'll add it to our hardware request list.
Thu May 26, 2016 12:55 am
rhanson offline
I have seen a few products by this company as well, but not tested them. I ran into it searching for a z-wave water shutoff valve.
Best distribution so far is from thesmartesthouse.com. Maybe their only distributor, in fact.
http://www.thesmartesthouse.com/collections/zooz/products/zooz-z-wave-plus-4-in-1-sensor-zse40
I love how they list Indigo as a supported platform.
I would upload the spec sheet here, but apparently pdf is not allowed. :roll: It is available at the link above, though.
Thu May 26, 2016 12:07 pm
noefresh offline
Could possibly be a knockoff of another manufacturer?
Sun Oct 02, 2016 2:28 pm
jstewart30 offline
Bought this off Amazon as it's well reviewed and one of the few options for temperature sensing. Still comes up as "routing slave" only. Anyone able to get this working or, if not, any plans on Indigo's side to support it after 4+ months since this thread was opened?
Mon Oct 03, 2016 8:17 am
Open the device config dialog and click on the Submit Device information button. That will hopefully provide all the information we need to add it in a future release.
Wed Dec 07, 2016 4:11 pm
InsteonDiego offline
Is this device now supported in the current release of Indigo?
Wed Dec 07, 2016 4:25 pm
The ZSE40 is support in 7.0.
Sat Jan 07, 2017 1:24 pm
aldera offline
Based on your comment, I went ahead and bought one and received it in the mail today. However, when I include it and sync it, all I get is the battery level. Here is the result of the syncing event:
Jan 7, 2017, 2:13:58 PM
Z-Wave Syncing - started for "033 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 11, 13, 25
Z-Wave Syncing - assigning return route to "033 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 027A, Notification Sensor - 20212101
Z-Wave Syncing - retrieved protocol version 4.05, app version 16.09
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 720 minutes
Z-Wave Syncing - device "033 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "033 - Notification Sensor"
Z-Wave Syncing - complete
Z-Wave sent "033 - Notification Sensor" status request
Z-Wave received "033 - Notification Sensor" status update battery level 100%
Still new to Indigo. Am I missing something? Thanks.
Sat Jan 07, 2017 1:55 pm
It'll take a little while for the sensor values to get updated.
Sat Jan 07, 2017 2:34 pm
aldera offline
Okay. Thanks. If there are multiple sensors, shouldn't the device's dialog box show them? Mine is just showing the blue "Settings" button. See the attached file. Usually, with multiple sensors, there is a row of blue buttons representing each sensor in the device.
Device Dialog Box
Sat Jan 07, 2017 2:54 pm
Hmm. I think yours has a different device definition than mine.
Screen Shot 2017-01-07 at 3.52.54 PM 1-7.png (118.38 KiB) Viewed 4498 times
Sat Jan 07, 2017 11:48 pm
aldera offline
I tried including it with and without encryption and I get the same results. Looks like yours got identified as a Zooz sensor. Mine is just being identified as a generic Notification sensor.
Any ideas? I'm stumped.
Sun Jan 08, 2017 10:32 am
aldera offline
If this helps any, here is the output from the sync after doing the include with encryption:
Jan 8, 2017, 11:26:17 AM
Z-Wave Syncing - started for "Sensor - Garage (Temp/Humidity)"
Z-Wave Syncing - assigning return route to "034 - Sensor - Garage (Temp/Humidity)"
Z-Wave Syncing - retrieved encrypt commands: 80 84 85 86 59 5A 31 70 71 72 73 7A
Z-Wave Syncing - device "034 - Sensor - Garage (Temp/Humidity)" wake interval changed to 720 minutes
And this is what was written when I clicked on the "Write to event log" button.
Jan 8, 2017, 11:27:23 AM
Z-Wave Indigo Device "Sensor - Garage (Temp/Humidity)" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.34
Node ID: 34
Model: Notification Sensor
Model ID: 20212101
Manufacturer: Unknown
Manufacturer ID: 027A
Application Version: 16.09
Library Type: 3
Class Name: Notification Sensor
Command Versions: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Encryption Status: Enabled for Commands 80 84 85 86 59 5A 31 70 71 72 73 7A
Features: routing, battery, beaming, security, waking
Neighbors: 2, 3
Associations: 1:[1]
Sun Jan 08, 2017 4:15 pm
Looks like that one uses a different device manufacturer code than the one we have defined in Indigo. We'll add yours to the next bug fix release of Indigo (7.0.3).
