matt (support) wrote:Looks like that one uses a different device manufacturer code than the one we have defined in Indigo. We'll add yours to the next bug fix release of Indigo (7.0.3).
Just my luck. Thanks.
Indigo Z-Wave Version: 2.0.68
Node ID: ...
Model: Notification Sensor
Model ID: 00030083
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 4.05
Application Version: 3.80
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 31v7 72v1 73v1 71v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: ...
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
jay (support) wrote:What version of Indigo are you using?
matt (support) wrote:We'll have this fixed in 7.0.4.
This is Zooz ZSE09 notification sensor. Can you please add a profile for it?
whmoorejr wrote:Just ordered / included 5 of them. I got the knockoff monoprice version.... https://www.monoprice.com/product?p_id=15902
My only glitch, the temp setting. Two of them I was able to change from the default C to F. The other three don't want to change and they are forcing me to do math.
