I have recently bought the Vision Wireless Garage Door Detector ZG8101 and syncing in to Indigo was easy.
Manual at for example http://www.vesternet.com/downloads/dl/f ... manual.pdf
I get nice signals when garage door opens and closes.
However, it seems that Indigo does not recognise the tamper signals?
If I set the Z-Wave log to debug mode I see activity when I pull of the cover and the tamper switch activates (I can see that as well since the red LED lights up).
This is what I see when tamper switch activates:
Tamper alarm
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 67 0A 71 05 07 FF 00 FF 07 03 00 00 F1
Z-Wave Debug . . requestAlarmSensorStatus: node 103, endpoint None, cmdClass 71, type 7, value 255
This is how the tilt on (i.e. garage door open/up) looks in the log
Door open
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 67 03 20 01 FF 48
Z-Wave Debug . . sensorSetLevel: node 103, endpoint None, cmdClass 20, value 255
Z-Wave received "103 - Garage door sensor - Tilt Sensor" status update is on
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 67 0A 71 05 07 FF 00 FF 07 02 00 00 F0
and this how the tilt off (i.e. garage door closed/down):
Door closed
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 67 03 20 01 00 B7
Z-Wave Debug . . sensorSetLevel: node 103, endpoint None, cmdClass 20, value 0
Z-Wave received "103 - Garage door sensor - Tilt Sensor" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 67 0A 71 05 07 00 00 FF 07 02 00 00 0F
Z-Wave Debug . . requestAlarmSensorStatus: node 103, endpoint None, cmdClass 71, type 7, value 0
And after I put back the cover and the red led goes off I see
Tamper off?
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 67 02 84 07 15
Z-Wave Debug . . nodeAwake: node 103
Z-Wave Debug . . . . . . . : skipping battery check (next check in 710 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 67 02 84 08 04 72 7A
Z-Wave Debug RCVD packet: 01 05 00 13 72 00 9B (hex)
and another log example when I put the cover back, i.e. tamper should go off
Z-Wave Debug . . . . . . . : skipping battery check (next check in 611 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 67 02 84 08 04 A3 AB
Z-Wave Debug RCVD packet: 01 05 00 13 A3 00 4A (hex)
So the first thing to do is to investigate why tamper alarm is not shown in the Indigo GUI or as an Z-Wave event in the log.
2nd thing is the reset of the tamper alarm.
Anyway, as I recently learned in viewtopic.php?f=77&t=15528 I can use delayed events to reset the tamper alarm but in this case it would be better to be able to reset the tamper alarm when the cover has been put back on the device
