Does this work with Indigosdomo ?
works with
HC2 HCLite Vera ZNet Lite Zipabox Homeseer RaZberry
see: http://www.sensative.com/strips.html
lalid wrote:Does this work with Indigosdomo ?
works with
2016-03-25 21:48:14.085 Z-Wave Indigo Device "031 - Door Strips" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.355
Node ID: 31
Model: Routing Slave
Model ID: 00030003
Manufacturer: Unknown
Manufacturer ID: 019A
Protocol Version: 4.05
Application Version: 0.01
Model Definition Version: 0
Library Type: 6
Class Name: Routing Slave
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 30v1 84v2 85v1 86v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 10, 12, 14, 15, 16, 17, 23, 24, 26, 27, 28
Associations: 1:[1]
Config Values: - none -
davinci wrote:Is this already working in the latest version of Indigo?
Shouldn't be that hard to add it. The product seems very practical.
