Qubino Flush shutter (ZMNHCD1)
Thu Jan 26, 2017 4:00 pm
Re: Qubino Flush shutter (ZMNHCD1)
This thread is old but I wanted to follow-up that Indigo 7.0 is now available (has been for a while). It adds supports for dozens of new Z-Wave devices, including the Qubino Flush Shutter (ZMNHCD1).
Wed Sep 29, 2021 10:00 am
MarcoGT offline
I have serious problems with this device.
I replaced a Fibaro Roller Shutter with this device and the push button do not work; calibration mode works, power report works, but if I set a "brightness", it does not work, I hear just a "tick" from the device.
It also seems that the brightness value changes continuously...
I wanted to buy a Fibaro again, but the version 3 seems not fully supported in Indigo
Here the device definition
   Z-Wave                          Indigo Device "Tapparella Portafinestra Soggiorno" Z-Wave Properties:
Indigo Z-Wave Version: 2021.1.1
Node ID: 32
Model: Flush Shutter (ZMNHCD)
Model ID: 00030052
Manufacturer: Qubino
Manufacturer ID: 0159
Protocol Version: 4.38
Application Version: 75.00
Model Definition Version: 3
Library Type: 3
Class Name: Motor Control Class C
Class Hierarchy: 04 : 11 : 07
Command Class Base: 26
Command Versions: 20v1 25v1 26v3 27v1 32v4 8Ev1 70v1 71v1 72v1 73v1 5Ev1 98v1 59v1 5Av1 86v1 85v1
Features: routing, beaming, security, energyMeter, powerMeter
Neighbors: 1, 4, 7, 20, 21, 26, 27, 28, 29, 30
Associations: 1:[1] 2:[] 3:[] 5:[] 7:[]
Config Values: 71:0 72:150 74:1 76:30 110:32536 120:5
Any idea?
Marco
Sat Oct 02, 2021 12:22 am
MarcoGT offline
So, problem was Parameter 74 which was set to 1 :roll:
Sun Oct 03, 2021 12:37 pm
Thanks for the follow-up. I guess that explains the 10 millisecond "tick" you would hear? :)
Sun Oct 03, 2021 1:18 pm
MarcoGT offline
Yes, exactly!
