Thank
//Jens
yassi wrote:What do you think? Battery, or the device?
autolog wrote:yassi wrote:What do you think? Battery, or the device?
Battery - It should be 3V - I have had these sensors stop working when the battery level is less than 2V
matt (support) wrote:andarv wrote:Model ID: 08011001
That is a new/different model ID than the previous ones we've seen. I've added it to Indigo so it should work in Indigo 6.1.7 once it is released.
Syncing - retrieved manufacture and model names: Fibaro System - 010F, Routing Slave - 08012001
Syncing - retrieved protocol version 4.05, app version 3.02
matt (support) wrote:I just added those model IDs to the next version for you, so watch the announcements for when v6.1.8 is available (no ETA on it yet).
Z-Wave Syncing - started for "155 - Routing Slave"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Motion Sensor (FGMS001) - 08011001
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v8 72v1 73v1 30v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "155 - Routing Slave" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - added group 2 association to interface
Z-Wave Syncing - added group 3 association to interface
Z-Wave Syncing - retrieved parameter 1 "Motion sensor sensitivity (8: most sensitive, 255: least sensitive)" is 15
Z-Wave Syncing - retrieved parameter 8 "Motion sensor mode (0: always active, 1: day only, 2: night only)" is 0
Z-Wave Syncing - retrieved parameter 6 "Delay after no motion before OFF sent" is 30 seconds
Z-Wave Syncing - retrieved parameter 9 "Night luminance threshold (used to determine day/night if mode 1 or 2 is used above)" is 200
Z-Wave Syncing - retrieved parameter 12 "Group 1 command type" is 0
Z-Wave Syncing - retrieved parameter 20 "Tamper sensor sensitivity (0: inactive, 1: most sensitive, 122: least sensitive)" is 20
Z-Wave Syncing - retrieved parameter 24 "Tamper operating mode" is 0
Z-Wave Syncing - retrieved parameter 40 "Luminance report sensitivity (0: disable reporting, 1 to 65535: lux)" is 200 LUX
Z-Wave Syncing - retrieved parameter 42 "Delay between reporting Luminance changes (0: disable reporting, 1 to 65535: seconds delay)" is 3600 seconds
Z-Wave Syncing - retrieved parameter 60 "Temperature change sensitivity (0: disable reporting, 1: 0.1°C, 2: 0.2°C, 10: 1.0°C, 20: 2.0°C, 50: 5.0°C, ..., 255: 25.5°C)" is 10
Z-Wave Syncing - retrieved parameter 62 "Delay between measuring temperature changes (0: disable measuring, 1 to 65535: seconds delay)" is 900 seconds
Z-Wave Syncing - retrieved parameter 64 "Delay between reporting temperature changes (0: disable reporting, 1 to 65535: seconds delay)" is 0 seconds
Z-Wave Syncing - retrieved parameter 66 "Temperature calibration offset in 0.1 degrees" is 0 * 0.1 degrees
Z-Wave Syncing - retrieved parameter 80 "LED signaling mode (see manual for values)" is 10
Z-Wave Syncing - retrieved parameter 81 "LED brightness (0: auto from ambient, 1 to 100: brightness percentage)" is 50
Z-Wave Syncing - retrieved parameter 82 "Luminance threshold for 1% LED brightness (only if LED brightness value is 0)" is 100 LUX
Z-Wave Syncing - retrieved parameter 83 "Luminance threshold for 100% LED brightness (only if LED brightness value is 0)" is 1000 LUX
Z-Wave Syncing - retrieved parameter 86 "Temperature threshold for triggering blue LED (only if LED signaling mode value is 1, 10, 19)" is 18 degrees
Z-Wave Syncing - retrieved parameter 87 "Temperature threshold for triggering red LED (only if LED signaling mode value is 1, 10, 19)" is 28 degrees
Z-Wave Syncing - retrieved parameter 89 "LED flashes red, white, blue on tamper" is true
Z-Wave Syncing - created device "155 - Motion Sensor"
Z-Wave Syncing - created device "155 - Tilt/Tamper"
Z-Wave Syncing - created device "155 - Temperature"
Z-Wave Syncing - created device "155 - Luminance"
Z-Wave Syncing - complete
Z-Wave Indigo Device "155 - Motion Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.362
Node ID: 155
Model: Motion Sensor (FGMS001)
Model ID: 08011001
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.05
Application Version: 3.02
Model Definition Version: 1
Library Type: 3
Class Name: Routing Slave
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v8 72v1 73v1 30v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1] 2:[1] 3:[1] 4:[] 5:[]
Config Values: 64:0 1:15 66:0 6:30 81:50 40:200 9:200 42:3600 12:0 80:10 8:0 82:100 83:1000 20:20 86:18 87:28 24:0 89:1 60:10 62:900
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 9B 09 71 05 00 00 00 FF 07 03 00 E9
Z-Wave Debug . . requestAlarmSensorStatus: node 155, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 3, classSubKeyExt 7100000703
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 08 9B 09 71 05 00 00 00 FF 07 03 00 E1
autolog wrote:I have just purchased some new Gen 5 Fibaro Motion Sensors which arrived today.
It does seem to be sensing motion, lux and temperature readings but not detecting tamper.
I turned on the Z-Wave debug and forced a tamper and got:Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 9B 09 71 05 00 00 00 FF 07 03 00 E9
matt (support) wrote:Try Indigo v6.1.8 which I just posted. It will hopefully be able to process the different tamper switch commands.
