Z-Wave Indigo Device "Walk In Robe" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.56
Node ID: 30
Model: Dimmable Power Switch
Model ID: 01023000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.05
Application Version: 3.03
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 60v4 22v1 26v3 86v1 27v1 7Av1 72v1 8Ev1 70v1 71v1 32v3 73v1 75v1 56v1 98v1 59v1 31v4 5Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(11 : 01), 2:(11 : 01)
Multi-Endpoint Classes: 1:[5E 20 86 26 85 59 8E 32 31 71], 2:[5E 20 86 26 85 59 8E]
Features: routing, beaming, security, energyMeter
Neighbors: 1, 2, 5, 6, 16, 17, 22, 26, 32, 33, 34, 35, 36, 41
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[]
Config Values: - none -
howartp wrote:I presume if you're using it for scenes, Indigo needs to be able to create triggers on switch 2 versus switch 1?
petematheson wrote:I still don't get the need for a switch 2 on these? (Installed some this weekend)
You can use it to control other 2wave devices - but why? They're z-wave so you'd just control them from the controller surely??
Is anyone using the switch 2 on these?
