Aeon Labs Aeotec ZW098-A52 RGBWW LED Bulb
Mon Nov 14, 2016 1:50 am
frryn offline
Re: Aeon Labs Aeotec ZW098-A52 RGBWW LED Bulb
Hi
Have anyone got the AEON Labs RGBW Bulb to work (set RGB levels) with Indigo 7?
Indigo 7 identifies the bulb as a RGB-device and sends commands to the device, but the device stays with current RGB-level set instead of changing.
/Fredrik
Mon Nov 14, 2016 1:51 am
Yes, mines been working through beta. (Assuming it's same model no - think it is).
I believe I had to exclude it and reinclude.
Mon Nov 14, 2016 10:20 am
I have one I've tested with pretty exhaustively. If it isn't working after a re-sync, then copy/paste the Event Log results of both the sync and the commands that are failing to change the RGB levels.
Thu Nov 24, 2016 9:22 am
toille27 offline
I've been having trouble with three of these Aeotec bulbs responding on a series 2 Z stick and was curious how other people are making out with it on Indigo 7. I found two other stories on threads about some of the bulbs being slow to respond and interfering with other z wave devices.
If I pair the bulb close to the controller it responds normally but once at a distance (where previous z wave bulbs that are not gen 5 have worked) it becomes unresponsive and causes Indigo to reboot the Z stick. When I bring the z wave bulb back close to the stick the stick no longer controls the bulb at all and it needs to be re-paired.
As an experiment I installed a Zipato RGBW Bulb at the same problematic outdoor location at it works fine.
Any feedback would be appreciated. Happy Holidays!
Thu Nov 24, 2016 12:17 pm
Interesting. Just as a note the one I've tested is within about 5 feet of the Z-Stick. I haven't tried moving it far away, but will over the next few days.
Mon Nov 28, 2016 12:21 am
dliccardo offline
I have three of these Aeotec bulbs linked and working reliably in Indigo 7, including color changes via the Indigo client app on my mac. In Indigo iOS, I can control brightness and on/off, but not color. Is this an expected current limitation?
If so, looking forward to getting color change support in the iOS app... I hope its on your list Matt!
Darren
Mon Nov 28, 2016 8:52 am
Hi Darren,
We plan on adding that capability to Indigo Touch in its next major rev.
Fri Jan 20, 2017 10:58 pm
DazaG offline
I have three of these and none will change color with Indigo 7, just white and dimmable, is there a setting I'm missing, is it because it includes as a dimmable power switch ?
21 Jan 2017, 3:46:39 pm
Z-Wave started controller inclusion mode
Z-Wave controller included module: 006 - Dimmable Power Switch
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "006 - Dimmable Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 2, 5
Z-Wave Syncing - assigning return route to "006 - Dimmable Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, RGBW LED Bulb (ZW098) - 02030062
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.04
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 33v1 85v1 26v2 27v1 2Bv1 2Cv1 70v1 72v1 73v1 5Ev1 59v1 7Av1 86v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - created device "006 - RGBW LED Bulb (ZW098)"
Z-Wave Syncing - complete
Z-Wave sent "006 - RGBW LED Bulb (ZW098)" status request
Z-Wave received "006 - RGBW LED Bulb (ZW098)" status update brightness 100
Z-Wave sent "006 - RGBW LED Bulb (ZW098)" set color to 0 100 0, -- --
Z-Wave sent "006 - RGBW LED Bulb (ZW098)" set color to -- -- --, 100 --
Z-Wave sent "006 - RGBW LED Bulb (ZW098)" set color to -- -- --, -- 100
Z-Wave sent "006 - RGBW LED Bulb (ZW098)" off
Z-Wave sent "006 - RGBW LED Bulb (ZW098)" on
Sat Jan 21, 2017 1:43 am
Set both whiteness sliders to 0 (W and W2), then try changing the RGB color swatch. Does that work? If not, then what visually do you see (at the bulb) as you change the color and the main brightness value (top edit field above the W and W2 edit fields)?
Sat Jan 21, 2017 9:14 pm
DazaG offline
Ahh, thats got it working, thanks Matt
Thu Jan 26, 2017 3:10 pm
This thread is old but I wanted to follow-up that Indigo 7.0 is now available (has been for a while). It includes supports for dozens of new Z-Wave devices, including the Gen 5 Aeotec modules.
