- Posted on
Sat Jun 27, 2015 2:15 pm
toille27
offline
Hi Matt,
Here is sensor contact closed
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 4F 03 20 01 FF 60
Z-Wave Debug . . basicSetState: node 079, endpoint None, value 255 (no node dispatch)
Here is sensor after opening contact
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 4F 03 20 01 00 9F
Z-Wave Debug . . basicSetState: node 079, endpoint None, value 0 (no node dispatch)
Redefine/Sync Z-Wave Debug
intiatingSyncUI (timeout in 300 seconds)
Z-Wave Syncing - started for device "Aeon Labs Dry Contact"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 4F 01 01 36
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 40 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0E
Z-Wave Debug . . getNodeNeighbors: nodeId 079, neighbors: 23, 37
Z-Wave Syncing - retrieved module neighbors list: 23, 37
Z-Wave Syncing - requesting neighbor list update of "079 - Aeon Labs Dry Contact"
Z-Wave Debug SENT requestNeighborUpdate: 01 04 00 48 4F FC
Z-Wave Debug RCVD requestNeighborUpdate: 06 (ACK)
Z-Wave Debug RCVD requestNeighborUpdate: 01 05 00 48 01 21 92
Z-Wave Debug . . requestNeighborUpdate: node 079, update starting
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 4F 02 84 07 3D
Z-Wave Debug . . nodeAwake: node 079 (queued awake processing because sync in progress)
Jun 27, 2015, 4:13:57 PM
Z-Wave Debug RCVD requestNeighborUpdate: 01 05 00 48 01 22 91
Z-Wave Debug . . requestNeighborUpdate: node 079, update finished
Z-Wave Syncing - neighbor list update complete (no change)
Z-Wave Syncing - assigning return route to "079 - Aeon Labs Dry Contact"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 4F 01 F2
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 079, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 4F 04 02 D0
Z-Wave Debug RCVD requestNodeInfo: 01 19 00 49 84 4F 13 04 07 01 5E 86 72 85 59 73 71 84 30 80 70 98 7A EF 5A 82 90
Z-Wave Debug . . requestNodeInfo: node 079, combined class list: 80v1 30v1 84v1 85v1 86v1 70v1 71v1 72v1 73v1 98v1 59v1 7Av1 5Ev1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 4F 02 72 04 05 03 D8
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 4F 08 72 05 00 86 01 02 00 61 21
Z-Wave Debug . . requestManufactureInfo: node 079, manufacturerId 0086, productId 01020061
Z-Wave Debug . . requestManufactureInfo: Aeon Labs, Routing Slave
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Routing Slave - 01020061
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 4F 02 86 11 05 04 3E
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 4F 09 86 12 03 04 05 01 04 61 00 40
Z-Wave Debug . . requestVersInfoGen: node 079, protoVers 4.05, appVers 1.04
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.04
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 4F 03 86 13 84 05 05 BB
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 4F 04 86 14 84 02 AE
Z-Wave Debug . . requestVersInfoCmdClass: node 079, class command 84 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 079, combined class list: 80v1 30v1 84v2 85v1 86v1 70v1 71v1 72v1 73v1 98v1 59v1 7Av1 5Ev1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 30v1 84v2 85v1 86v1 70v1 71v1 72v1 73v1 98v1 59v1 7Av1 5Ev1
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 4F 02 84 05 05 06 2A
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 4F 06 84 06 00 0E 10 01 23
Z-Wave Debug . . requestWakeInterval: node 079, interval 60 minutes, wakeTarget 001
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 4F 06 84 04 00 0E 10 01 05 07 35
Z-Wave Syncing - device "079 - Aeon Labs Dry Contact" wake interval changed to 60 minutes
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 4F 02 85 05 05 08 25
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 4F 03 85 06 01 3C
Z-Wave Debug . . requestAssociationGroupCount: node 079, group count: 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 4F 03 85 02 01 05 09 20
Z-Wave Debug RCVD requestAssociations: 01 09 00 04 00 4F 03 85 06 01 3C (unsolicited2 -- requeuing)
Z-Wave Debug RCVD requestAssociations: 01 09 00 04 00 4F 03 85 06 01 3C (unsolicited3 -- requeuing)
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 4F 06 85 03 01 05 00 01 3D
Z-Wave Debug . . requestAssociations: node 079, group: 1, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 079, group: 1, associations: [1]
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 4F 02 80 02 05 0A 25
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 4F 03 80 03 64 59
Z-Wave Debug . . requestBatteryLevel: node 079, level 100
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 4F 02 80 02 05 0B 24
Z-Wave Debug terminatingSyncUI
Z-Wave received "079 - Aeon Labs Dry Contact" status update battery level 100%
Z-Wave Debug SENT goToSleep: 01 09 00 13 4F 02 84 08 04 0C 2C
Z-Wave Debug RCVD packet: 01 05 00 13 0C 00 E5 (hex)
