Since my Philio PST02-1C sensors are not yet supported I went out and purchased a couple of Vision ZD2102 door sensors.
I checked to make sure that support was included in Indigo before I purchased these.
When adding them to Indigo, they only show up as a routing slave though.
I now have 4 sets (around 200 euro) of door sensors that are not working with Indigo, is there a way to get any of these working please ?
I already submitted the device info, but here is what shows up in the event log.
When adding the sensor to Indigo :
Z-Wave Syncing - started for device "008 - Routing Slave"
Z-Wave Syncing - assigning return route to "008 - Routing Slave"
Z-Wave Syncing - retrieved manufacture and model names: Vision / Yale - 0109, Routing Slave - 20010106
Z-Wave Syncing - retrieved protocol version 4.05, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 70v1 71v1 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "008 - Routing Slave" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved battery level of 90%
Z-Wave Syncing - created device "008 - Routing Slave"
Z-Wave Syncing - complete
Z-Wave received "008 - Routing Slave" status update battery level 90%
When the magnet opens :
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 08 03 20 01 FF 27
Z-Wave Debug . . basicSetState: node 008, endpoint None, value 255 (no node dispatch)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 08 0A 71 05 06 FF 00 FF 06 16 00 00 8B
Z-Wave Debug . . requestAlarmSensorStatus: node 008, endpoint None, cmdClass 71, type 6, value 255
When the magnet closes :
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 08 03 20 01 00 D8
Z-Wave Debug . . basicSetState: node 008, endpoint None, value 0 (no node dispatch)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 08 0A 71 05 06 00 00 FF 06 17 00 00 75
Z-Wave Debug . . requestAlarmSensorStatus: node 008, endpoint None, cmdClass 71, type 6, value 0
I have to add that the model number on the box is VIS_ZD2102-5
This is a Zwave plus device, so I think it is slightly different from the one that is currently supported in Indigo
