Devolo finally brought his Room Thermostat "Devolo Home Control Raumthermostat" to the german market (see http://www.devolo.com/de/Produkte/devol ... thermostat). It's the Z-Wave version of the Danfoss Link RS.
Inclusion was quiet easy, even though the manual only describes the installation with Devolos gateway. All you have to do ist press the button on top (left side) once.
The Room Thermostat is listed as "Multilevel Sensor (routing)" and only shows the momentary temperature - even so it's possible to set a heat setpoint directly at the device.
Here's the information I get from the device:
- Code: Select all
address : 47
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : 100
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwValueSensorType
displayStateId : sensorValue
displayStateImageSel : TemperatureSensor
displayStateValRaw : 20.37
displayStateValUi : 20.37 °C
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
com.perceptiveautomation.indigoplugin.zwave : (dict)
SensorUnits : 1 (integer)
SupportsBatteryLevel : true (bool)
SupportsEnergyMeter : false (bool)
SupportsEnergyMeterCurPower : false (bool)
SupportsEnergyMeterReset : false (bool)
SupportsOnState : false (bool)
SupportsSensorValue : true (bool)
TempUnits : 1 (integer)
address : 47 (integer)
propsPushTickler : 2 (string)
tempAlwaysFalse : false (bool)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 60 (integer)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 0 (integer)
zwAssociationsMap : (dict)
zwAssociationsMapStr : - none - (string)
zwClassCmdBase : 49 (integer)
zwClassCmdMap : (dict)
c112 : 1 (integer)
c114 : 1 (integer)
c117 : 1 (integer)
c128 : 1 (integer)
c132 : 2 (integer)
c134 : 1 (integer)
c135 : 1 (integer)
c143 : 1 (integer)
c32 : 1 (integer)
c49 : 6 (integer)
c67 : 1 (integer)
c83 : 1 (integer)
c91 : 1 (integer)
zwClassCmdMapStr : 20v1 80v1 43v1 84v2 86v1 87v1 8Fv1 70v1 31v6 72v1 53v1 75v1 5Bv1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 33 (integer)
Item : 1 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Multilevel Sensor (routing) (string)
zwConfigVals : (dict)
zwConfigValsStr : - none - (string)
zwDevSubIndex : 0 (integer)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, battery, beaming, waking (string)
zwLibType : 6 (integer)
zwManufactureId : 2 (integer)
zwManufactureName : Danfoss (string)
zwMeterSubTypeFlags : 0 (integer)
zwMeterSupportsReset : false (bool)
zwMeterType : 0 (integer)
zwModelDefnVers : 0 (integer)
zwModelId : 229392 (integer)
zwModelName : Multilevel Sensor (routing) (string)
zwNodeNeighbors : (list)
Item : 1 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 14 (integer)
Item : 34 (integer)
Item : 37 (integer)
Item : 39 (integer)
Item : 40 (integer)
Item : 41 (integer)
Item : 42 (integer)
zwNodeNeighborsStr : 1, 3, 4, 5, 14, 34, 37, 39, 40, 41, 42 (string)
zwProtoVersMajor : 3 (integer)
zwProtoVersMinor : 67 (integer)
zwShowMainUI : true (bool)
zwShowPollingUI : false (bool)
zwShowWakeIntervalUI : true (bool)
zwWakeInterval : 60 (integer)
lastChanged : 2015-04-25 07:07:49
model : Multilevel Sensor (routing)
onState : None
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
sensorValue : 20.37
states : States : (dict)
batteryLevel : 100 (integer)
batteryLevel.ui : 100% (string)
sensorValue : 20.370000 (real)
sensorValue.ui : 20.37 °C (string)
subModel :
supportsAllOff : False
supportsStatusRequest : True
version : 0
Thanks to the possibility to see the Event Log live on the new Indigo Touch App (great work, guys!) I was able to figure out, that Indigo actually receivers the heat setpoint. But after that the Log shows the following error two times:
device "Thermostat Bad" state key setpointHeat not defined (ignoring update request)
Any suggesting what I can do so I can use the heat stepping? Thanks in advance!
Best,
Nico
