Hi guys,
I bought a couple of these Philio PST02-1B Philio Tech 3-in-1-sensors.
I have 4 of the old version (PST01) and they are working perfect.
At this moment the PST02 series are recognized by Indigo as a Slave module.
And that's not right
Below the results/different of the 2 versions (old and new).
Please could you add this module to the Indigo support list.
The old ones are not deliverable anymore, so now we have 2 modules we can't use
Thanks for all your work and kind regards,
John
The (old) PSP01;
Z-Wave Indigo Device "Carport Motion " Z-Wave Properties:
Indigo Z-Wave Version: 1.0.355
Node ID: 71
Model: Multi Sensor (PSM/PSP)
Model ID: 00020002
Manufacturer: Philio
Manufacturer ID: 013C
Protocol Version: 3.41
Application Version: 1.00
Model Definition Version: 2
Library Type: 6
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 31v5 72v1
Features: routing, battery, beaming, waking
Neighbors: 1, 11, 12, 15, 16, 17, 22, 25, 27, 33, 38, 39, 40, 45, 48, 54, 56, 57, 60, 61, 62, 66
Associations: 1:[1] 2:[]
Config Values: 3:70 4:99 5:8 6:5 7:6 8:3 9:4 10:12 11:12 12:1 13:1
The NEW PST02
Z-Wave Indigo Device "085 - Routing Slave" Z-Wave Properties:
Node ID: 85
Model: Routing Slave
Model ID: 0002000D
Protocol Version: 3.95
Application Version: 1.16
Model Definition Version: 0
Library Type: 3
Class Name: Routing Slave
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 70v1 84v2 85v1 86v1 71v1 8Fv1 30v1 31v5 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Neighbors: 1, 11, 12, 15, 16, 17, 22, 25, 27, 33, 34, 38, 39, 40, 41, 45, 48, 54, 56, 57, 60, 62, 64, 65, 77
Config Values: - none -
