Hello.
I just get this product (4 times ) and trying it.
To say, I'm surprised it was totally found and setup seems good : one device, on address but 6 items ... each have energy and on/off in the device list options.
The only thing is, does this work correctly.
For all of them, they often start blinking with the bars, which means "PowerNode is out of range from the Gateway". But it's not the case as I can turn any switch on or off, or ask status without any problems. Even 5 minutes polling works. But it often goes back with this blink.
And the device is known to not poll itself (like if you press the on/off button on the device itself, all plugs are turned on or off, but it does not return this to the gateway).
But why this ?
And another thing : the energy status is wrong on one of my device, even the status of the 6th plug return the wrong information.
So before I get this for exchange, is there any possibility that it's something wrong with the interface or indigo communications / interpretation for this model ?
Here is the product link where I bought it (french) : http://www.swiss-domotique.ch/index.php ... Ports.html
And the log of the problematic device :
030004
Manufacturer: GreenWave
Manufacturer ID: 0099
Protocol Version: 3.41
Application Version: 4.27
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v3 25v1 86v1 87v1 27v1 32v2 70v1 71v1 72v1 75v1 56v1 85v1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01), 4:(10 : 01), 5:(10 : 01), 6:(10 : 01)
Multi-Endpoint Classes: 1:[20 25 32 75], 2:[20 25 32 75], 3:[20 25 32 75], 4:[20 25 32 75], 5:[20 25 32 75], 6:[20 25 32 75]
Features: routing, beaming, energyMeter
Neighbors: 1, 5, 8, 9, 11, 12, 13, 14, 16, 18, 19, 20, 21, 22, 24, 25, 26, 27, 28, 29, 30, 31
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
And of a less problematic one (still blinking so ) :
Indigo Z-Wave Version: 1.0.301
Node ID: 35
Model: Relay Power Switch
Model ID: 00030004
Library Type: 3
Neighbors: 1, 8, 9, 11, 13, 14, 16, 18, 19, 20, 21, 25, 26, 27, 28, 29, 30, 31, 34
