- Posted on
Thu Feb 02, 2017 1:32 pm
Sharek326
offline
Here is what was in the event log for that sync
Feb 2, 2017, 2:30:59 PM
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
Z-Wave Debug . . getVersion: Z-Wave 2.78 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 01 84 E2 15 01 A5
Z-Wave Debug . . getHomeID: 0184E215, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 3F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 82
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 10 12 13 14 15 16 17 18 1C 20 21 22 23 24 41 42 44 45 46 47 48 49 4A 4B 4D 50 51 52 53 54 55 56 5A 60 61 62 63 80 90
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D FD DE 93 FF DF FD FF 07 10 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 BE
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 3, 4, 5, 6, 7, 8, 10, 11, 12, 13, 15, 16, 17, 18, 21, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 39, 40, 41, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 69, 85, 86, 87, 88]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 12 16 00 01 02 01 B0
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : Static Controller : Static Computer Controller (01 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 03 EE
Z-Wave Debug . . getNodeProtocolInfo: node 004, class name: Relay Scene Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Scene Switch (04 : 10 : 03)
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27 2B 2C 72
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 A1 00 DC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Sensor Alarm
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Sensor Alarm : -- (04 : A1 : 00)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 71
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 71 72
Z-Wave Debug overriding node 006 type from zwCustomType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 52 9C 00 04 20 01 5D
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Binary Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 30
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 30
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0A B0
Z-Wave Debug . . getNodeProtocolInfo: node 010, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0C B6
Z-Wave Debug . . getNodeProtocolInfo: node 012, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0D B7
Z-Wave Debug . . getNodeProtocolInfo: node 013, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0F B5
Z-Wave Debug . . getNodeProtocolInfo: node 015, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 10 AA
Z-Wave Debug . . getNodeProtocolInfo: node 016, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 11 AB
Z-Wave Debug . . getNodeProtocolInfo: node 017, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 12 A8
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 15 AF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 52 DC 00 04 08 06 32
Z-Wave Debug . . getNodeProtocolInfo: node 021, class name: General Thermostat (v2)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 40
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 40 72 43 86
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming, frequentWaking
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 18 A2
Z-Wave Debug . . getNodeProtocolInfo: node 024, class name: General Thermostat (v2)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 19 A3
Z-Wave Debug . . getNodeProtocolInfo: node 025, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1A A0
Z-Wave Debug . . getNodeProtocolInfo: node 026, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1B A1
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 31 01 CD
Z-Wave Debug . . getNodeProtocolInfo: node 027, class name: Simple Meter
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Meter : Simple Meter (04 : 31 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 32
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 32 72 86
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1C A6
Z-Wave Debug . . getNodeProtocolInfo: node 028, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1D A7
Z-Wave Debug . . getNodeProtocolInfo: node 029, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1E A4
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 20 01 5C
Z-Wave Debug . . getNodeProtocolInfo: node 030, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1F A5
Z-Wave Debug . . getNodeProtocolInfo: node 031, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 20 9A
Z-Wave Debug . . getNodeProtocolInfo: node 032, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 21 9B
Z-Wave Debug . . getNodeProtocolInfo: node 033, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 22 98
Z-Wave Debug . . getNodeProtocolInfo: node 034, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 23 99
Z-Wave Debug . . getNodeProtocolInfo: node 035, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 24 9E
Z-Wave Debug . . getNodeProtocolInfo: node 036, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 25 9F
Z-Wave Debug . . getNodeProtocolInfo: node 037, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 27 9D
Z-Wave Debug . . getNodeProtocolInfo: node 039, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 28 92
Z-Wave Debug . . getNodeProtocolInfo: node 040, class name: Sensor Alarm
Z-Wave Debug overriding node 040 type from zwCustomType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 29 93
Z-Wave Debug . . getNodeProtocolInfo: node 041, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2B 91
Z-Wave Debug . . getNodeProtocolInfo: node 043, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2C 96
Z-Wave Debug . . getNodeProtocolInfo: node 044, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2D 97
Z-Wave Debug . . getNodeProtocolInfo: node 045, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2E 94
Z-Wave Debug . . getNodeProtocolInfo: node 046, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 2F 95
Z-Wave Debug . . getNodeProtocolInfo: node 047, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 30 8A
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 12 96 00 01 01 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 048, class name: Portable Remote Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 31 8B
Z-Wave Debug . . getNodeProtocolInfo: node 049, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 32 88
Z-Wave Debug . . getNodeProtocolInfo: node 050, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 33 89
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 05 E9
Z-Wave Debug . . getNodeProtocolInfo: node 051, class name: Siren
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Siren (04 : 10 : 05)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 34 8E
Z-Wave Debug . . getNodeProtocolInfo: node 052, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 35 8F
Z-Wave Debug . . getNodeProtocolInfo: node 053, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 36 8C
Z-Wave Debug . . getNodeProtocolInfo: node 054, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 37 8D
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 A1 02 DE
Z-Wave Debug . . getNodeProtocolInfo: node 055, class name: Alarm Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Sensor Alarm : Alarm Sensor (routing) (04 : A1 : 02)
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 80 85 86 71 72
Z-Wave Debug . . getNodeProtocolInfo: features: routing, battery, beaming
Z-Wave Debug overriding node 055 type from zwCustomType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 38 82
Z-Wave Debug . . getNodeProtocolInfo: node 056, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 39 83
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 07 01 FA
Z-Wave Debug . . getNodeProtocolInfo: node 057, class name: Notification Sensor
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3A 80
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A
Z-Wave Debug . . getNodeProtocolInfo: node 058, class name: Notification Sensor
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3B 81
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 DC 00 04 40 03 7E
Z-Wave Debug . . getNodeProtocolInfo: node 059, class name: Keypad Door Lock
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 62
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 62 63 86 72 98
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming, security, frequentWaking
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 45 FF
Z-Wave Debug . . getNodeProtocolInfo: node 069, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 55 EF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 40 07 BA
Z-Wave Debug . . getNodeProtocolInfo: node 085, class name: Secure Barrier Add-On
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 66
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 66
Z-Wave Debug overriding node 085 type from zwLockType to zwRelayType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 56 EC
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 086, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 57 ED
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 21 01 5C
Z-Wave Debug . . getNodeProtocolInfo: node 087, class name: Multilevel Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 31
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 31
Z-Wave Debug overriding node 087 type from zwValueSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 58 E2
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 13 96 01 01 01 06 34
Z-Wave Debug . . getNodeProtocolInfo: node 088, class name: Remote Control Simple
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : Portable Controller : Remote Control Simple (01 : 01 : 06)
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 58 06 84 04 01 51 80 01 25 97 5C
Z-Wave Debug RCVD setWakeInterval: 01 05 00 13 97 01 7F (node NAK)
Z-Wave Error device "Upstairs Scene Controller" may be asleep. configuration changes will be set during the next wake interval.
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "Garage Door"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 55 01 01 2C
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 50 9E 93 DF 0B 74 BF 01 10 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6D
Z-Wave Debug . . getNodeNeighbors: nodeId 085, neighbors: 5, 7, 10, 11, 12, 13, 16, 17, 18, 21, 24, 25, 26, 27, 28, 29, 31, 32, 33, 34, 36, 43, 45, 46, 47, 49, 50, 51, 52, 53, 54, 56, 57, 69, 86, 87
Z-Wave Syncing - retrieved module neighbors list: 5, 7, 10, 11, 12, 13, 16, 17, 18, 21, 24, 25, 26, 27, 28, 29, 31, 32, 33, 34, 36, 43, 45, 46, 47, 49, 50, 51, 52, 53, 54, 56, 57, 69, 86, 87
Z-Wave Syncing - assigning return route to "085 - Garage Door"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 55 01 E8
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 085, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 55 24 98 70
Z-Wave Debug RCVD nodeInfoFrame: 01 0C 00 49 84 55 06 04 40 07 72 98 5A 9E
Z-Wave Debug . . nodeInfoFrame: node 085, combined class list: 20v1 98v1 72v1 5Av1 66v1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 55 02 98 40 25 99 D6
Z-Wave Debug RCVD nonceReport: node 085, nonce B9 AB D7 67 B1 5F EA 3A
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 085, nonce 9D 9B 10 01 F6 C5 8C 45 (saving)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 39 06 31 05 03 0A 00 00 F5
Z-Wave Debug . . requestVarSensorStatus: node 057, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 0 lux (float: 0.000000)
Z-Wave received "Crawl Space - Luminance" sensor update to 0 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 39 06 31 05 01 2A 02 34 E1
Z-Wave Debug . . requestVarSensorStatus: node 057, endpoint None, type 1, raw value 2A02...
Z-Wave Debug . . requestVarSensorStatus: 56.4 °F (float: 56.400000)
Z-Wave received "Crawl Space - Temperature" sensor update to 56.4 °F
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 39 06 31 05 05 01 15 00 ED
Z-Wave Debug . . requestVarSensorStatus: node 057, endpoint None, type 5, raw value 0115...
Z-Wave Debug . . requestVarSensorStatus: 21% (float: 21.000000)
Z-Wave received "Crawl Space - Humidity" sensor update to 21%
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 55 02 72 04 25 9B 7A
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 55 08 72 05 01 4F 47 44 30 30 92
Z-Wave Debug . . requestManufactureInfo: node 085, manufacturerId 014F, productId 47443030
Z-Wave Debug . . requestManufactureInfo: LinearLinc, Garage Door Controller (GD00Z-4)
Z-Wave Syncing - retrieved manufacture and model names: LinearLinc - 014F, Garage Door Controller (GD00Z-4) - 47443030
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07, base 66)
Z-Wave Syncing - retrieved command classes: 20v1 98v1 72v1 5Av1 66v1
Z-Wave Syncing - retrieved encrypt commands: 66
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - complete
Z-Wave Debug SENT nonceRequest: 01 09 00 13 55 02 98 40 25 9C D3
Z-Wave Debug terminatingSyncUI
Z-Wave Debug RCVD nonceReport: node 085, nonce BE 46 86 6E 1A 47 AF 3B
Z-Wave Debug SENT requestBarrierStatus: 66 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 085, nonce 4B 0D 75 9A 22 98 C1 DC (saving)
Z-Wave sent "Garage Door" status request
