[ANSWERED]: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Opener
Sat Apr 15, 2017 7:08 pm
jfeger offline
Re: [ANSWERED]: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Op
Well, I now have four of these units, and can't seem to get them to work.
Matt, do you guys want me to send you one or two for experimenting? I am really hopeful we figure this out.
james
Sun Apr 16, 2017 2:37 pm
Hi James,
So you bought another one or two and they don't work either? Can you send me some debug logging snippets of a Sync along with any commands that Indigo receives/logs when you operate the garage door – both via Indigo and manually from the garage switch? If you have models with different firmwares now, then let's do this debugging with the most recent firmware version you have.
Wed Apr 26, 2017 4:32 pm
jfeger offline
Hi Matt,
I will ... its a back burner thing for me at the moment.
Sat Jun 24, 2017 2:59 pm
stoney offline
I just bought a couple of these garage door openers from Amazon.
<https://www.amazon.com/gp/product/B00M75TEIU/>
On the back label, it says: DATE: 17114, H/W Rev B, F/W Ver 2.1.
I've installed one so far. It works, is encrypted, but Indigo apparently doesn't understand the status. When I Request Status, I get this:
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 6B 74
Z-Wave Debug RCVD nonceReport: node 005, nonce 5F 11 0D 66 B6 83 B8 9A
Z-Wave Debug SENT requestBarrierStatus: 66 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 005, nonce A0 A9 E1 26 3F B0 C5 93 (saving)
Z-Wave sent "Left Garage Door" status request
The second RCVD is never the same value twice. The device always shows as "off" in the status display.
When I "included" it in encrypted mode, I got this:
Z-Wave started controller inclusion mode with encryption
Z-Wave controller included module: 005 - Secure Barrier Add-On
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
When I sync it, I get this:
Z-Wave Syncing - retrieved manufacture and model names: LinearLinc - 014F, Garage Door Controller (NGD00Z) - 47443530
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07, base 66)
Z-Wave Syncing - retrieved command classes: 20v1 66v1 72v1 73v1 98v1 5Av1 5Ev1
Z-Wave Syncing - retrieved encrypt commands: 66
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - complete
Sending the device details to the log produces this:
Z-Wave Indigo Device "Left Garage Door" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 5
Model: Garage Door Controller (NGD00Z)
Model ID: 47443530
Manufacturer: LinearLinc
Manufacturer ID: 014F
Protocol Version: 0.00
Application Version: 0.00
Model Definition Version: 1
Library Type: 0
Class Name: Secure Barrier Add-On
Class Hierarchy: 04 : 40 : 07
Command Class Base: 66
Command Versions: 20v1 66v1 72v1 73v1 98v1 5Av1 5Ev1
Encryption Status: Enabled for Commands 66
Features: routing, beaming, security
Neighbors: 3
Associations: - none -
Config Values: - none -
In the Edit Device Settings dialog, I see "Garage Door Controller (NGD00Z), firmware 0.00".
My interface is a Aeotec Z-Stick Gen 5. It's logged as "Z-Stick Plus (ZW090) interface on /dev/cu.usbmodemFA1341 (firmware 1.00)" after being reset.
This isn't useful to me without being able to get the device status. Does Firmware 2.1 break Indigo support? Is there any way to fix this?
Thanks.
- Stoney
Sat Jun 24, 2017 4:41 pm
Try this beta release of the Z-Wave library. Double-click it to install it (you might have to double-click twice – once to unzip it). After it is installed re-sync your module in Indigo and try the status request. If it doesn't help then copy/paste the results of everything into a reply for me.
Sat Jun 24, 2017 5:29 pm
stoney offline
The Garage door device now fails to sync. I turned on Z-wave debug, and got this:
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "Left Garage Door"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 05 01 01 7C
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A
Z-Wave Debug . . getNodeNeighbors: nodeId 005, neighbors: 3
Z-Wave Syncing - retrieved module neighbors list: 3
Z-Wave Syncing - assigning return route to "005 - Left Garage Door"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 05 01 B8
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 005, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 05 24 08 B0
Z-Wave Debug RCVD nodeInfoFrame: 01 0E 00 49 84 05 08 04 40 07 5E 5A 72 73 98 EF
Z-Wave Debug . . nodeInfoFrame: node 005, combined class list: 20v1 66v1 72v1 73v1 98v1 5Av1 5Ev1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 09 16
Z-Wave Debug RCVD nonceReport: node 005, nonce 11 AD 82 60 EC 79 70 A5
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 005, nonce 1A 87 E7 21 03 CF BE 44 (saving)
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 05 02 72 04 25 0B BA
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 05 08 72 05 01 4F 47 44 35 30 C7
Z-Wave Debug . . requestManufactureInfo: node 005, manufacturerId 014F, productId 47443530
Z-Wave Debug . . requestManufactureInfo: LinearLinc, Garage Door Controller (NGD00Z)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 0C 13
Z-Wave Debug RCVD nonceReport: node 005, nonce 9E 3C 81 BB DD 90 FE F0
Z-Wave Debug SENT requestVersInfoGen: 86 11 (encrypted)
Z-Wave Debug RCVD nonceReport: node 005, nonce 53 F6 6D FB 39 A5 A8 BD (saving)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 0E 11
Z-Wave Debug RCVD nonceReport: node 005, nonce AF 74 4C 73 3F FF 78 3A
Z-Wave Debug RCVD nonceReport: node 005, nonce 71 AA 55 9D 71 7A F1 93 (saving)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 10 0F
Z-Wave Debug RCVD nonceReport: node 005, nonce 7A 67 A0 65 F4 C6 EE 97
Z-Wave Debug RCVD nonceReport: node 005, nonce 02 EF 0E 90 B1 05 62 D8 (saving)
Z-Wave Debug maximum retry count exceeded waiting reply from module
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "005 - Left Garage Door". Module might be asleep, or is unreachable.
Z-Wave Debug terminatingSyncUI
I should clarify that I'm using Indigo 7.0.3 on OS X 10.12.5. I have been using an Insteon interface for years, but just added the Z-stick. The only Z-wave devices I have installed are the garage door opener and two Aeotec Range Extender 6's. I did not exclude and re-include the GDO after loading your new Z-wave plugin. That's rather a PITA since I can't reach the GDO button without a ladder.
Before I added the new Z-wave plugin, I could control the GDO from Indigo, but now I can't.
Mon Jun 26, 2017 2:24 pm
BaldDaddy offline
I just bought and installed 3 of these garage door openers as well to replace the Insteon ones that failed. I too am running the latest version of Indigo, as well as the updated Z-Wave drivers. I have not been able to sync the controllers thinking it was a Z-Stick issue being that I was running on an S2. I received a Gen5 today and still no joy. Please advise.
Eric
Mon Jun 26, 2017 2:34 pm
jalves offline
What does it show in the log when you try to sync these?
Jeff
Mon Jun 26, 2017 4:16 pm
BaldDaddy offline
Tried both with encryption and without. The dump below is with encryption enabled.
Z-Wave Debug SENT enterInclusionMode: 01 04 00 4A C1 70
Z-Wave Debug RCVD enterInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 02 01 00 00 B1
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave stopping controller inclusion mode
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 02 06 00 00 B6
Z-Wave Syncing - started for "004 - Secure Barrier Add-On"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 04 01 01 7D
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 58
Z-Wave Debug . . getNodeNeighbors: nodeId 004, neighbors: 2, 3
Z-Wave Syncing - retrieved module neighbors list: 2, 3
Z-Wave Syncing - assigning return route to "004 - Secure Barrier Add-On"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 04 01 B9
Z-Wave Debug . . assignReturnRoute: node 004, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 04 24 30 89
Z-Wave Debug RCVD nodeInfoFrame: 01 0E 00 49 84 04 08 04 40 07 5E 5A 72 73 98 EE
Z-Wave Debug . . nodeInfoFrame: node 004, combined class list: 20v1 66v1 72v1 73v1 98v1 5Av1 5Ev1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 04 02 72 04 25 31 81
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 04 08 72 05 01 4F 47 44 35 30 C6
Z-Wave Debug . . requestManufactureInfo: node 004, manufacturerId 014F, productId 47443530
Z-Wave Debug overriding node 004 type from zwLockType to zwRelayType
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 04 02 86 11 25 32 63
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 04 02 86 11 25 33 62
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 04 02 86 11 25 34 65
Z-Wave Error Timeout waiting for "004 - Secure Barrier Add-On". Module might be asleep, or is unreachable.
Eric
Mon Jun 26, 2017 4:31 pm
BaldDaddy offline
I put my S2 Z-Stick back in and switched it back to the SLAB_USBtoUART Serial port and now none of my devices are being recognized. Indigo is completely hosed. Below is the dump with just the first device being displayed as the remained 34 devices are showing the same information. Any help would be appreciated. Probably just a dumb mistake I am overlooking. Hopefully.
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
Z-Wave Debug . . getVersion: Z-Wave 2.78 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 01 6A 13 C5 01 6A
Z-Wave Debug . . getHomeID: 016A13C5, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 7F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 10 12 13 14 15 16 17 18 1C 20 21 22 23 24 41 42 44 45 46 47 48 49 4A 4B 4D 50 51 52 53 54 55 56 57 5A 60 61 62 63 80 90
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D FF 7F F7 BD 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 00
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 17, 18, 19, 21, 22, 23, 24, 25, 27, 28, 29, 30, 32, 33]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 92 16 00 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 11 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave found module included in controller with no matching device (missing or disabled): 002 - Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Eric
Tue Jun 27, 2017 5:56 am
BaldDaddy offline
As to the second problem I was having with the old S2 not recognizing any of my existing devices. Had to redefine and sync every device again. What a PITA. Why it lost all of its data when I plugged in the Gen5, no idea. Still no joy with the Gen5 and the garage door controllers.
Eric
Tue Jun 27, 2017 7:19 am
If you plug in a different Z-Wave controller then Indigo will detect that the node/module information stored in the controller doesn't match what it should (ex: node with address 004 is no longer the motion sensor Indigo expects), so Indigo takes communication offline for those devices, otherwise you would get very unexpected/unintended results. Once you have the normal Z-Stick plugged back in you don't have to do a full re-sync, but instead you can right-click on each device (still somewhat of a pain) and choose the menu item to Enable Indigo Communication.
Tue Jun 27, 2017 7:23 am
Argh. These modules really don't seem to be up to specification. I'm going to purchase one so I can troubleshoot it here. Folks that have recently bought one that isn't working: where did you purchase it from? Looks like Stoney got a couple from Amazon. Others? I want to make sure I get a "bad" one.
Tue Jun 27, 2017 6:28 pm
BaldDaddy offline
Amazon for me as well.
Eric
Tue Jun 27, 2017 10:22 pm
Sharek326 offline
Mine which has been a problem from the start and still doesn't work right was purchased from Lowes. I can only make it work correctly if I bridge it with Vera
