[ANSWERED]: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Opener
Fri Mar 13, 2015 1:50 pm
tedco offline
Any idea if Indigo can support the above device?
http://www.amazon.com/gp/product/B00M75 ... UTF8&psc=1
Many thanks,
Ted
Sun Mar 15, 2015 10:36 am
Re: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Opener
Hi Ted,
We have reports of people with the Vision/Yale Garage Door Tilt Sensor (ZG8101) and the Ecolink Garage Door Tilt Sensor (TILTZWAVE2), but I haven't heard of anyone using the Linear yet. It might work with the current Indigo, or we might need to add a model definition to Indigo for it.
Sun Mar 15, 2015 11:40 am
Sharek326 offline
Re: [ANSWERED]: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Op
That looks very similar to the IRIS one. I tried the IRIS with no luck.
http://www.lowes.com/pd_589237-78427-GD ... d=50213045
Sun Mar 15, 2015 12:09 pm
Define/Sync it from Indigo then copy/paste the Event Log results and we'll look into it.
Fri May 22, 2015 1:07 pm
tedco offline
I think this is the relevant information from the log - I also submitted a new device thing - although the manufacturer was UNKNOWN.
Ted
2015-05-22 14:38:36.765 Z-Wave Debug starting serial connection loop
2015-05-22 14:38:36.772 Z-Wave Debug starting zwave packet parser thread
2015-05-22 14:38:36.773 Z-Wave Debug SENT getVersion: 01 03 00 15 E9
2015-05-22 14:38:36.776 Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
2015-05-22 14:38:36.776 Z-Wave Debug . . getVersion: Z-Wave 2.78 static controller
2015-05-22 14:38:36.777 Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
2015-05-22 14:38:36.781 Z-Wave Debug RCVD getHomeID: 01 08 01 20 01 6A 0C DC 01 6C
2015-05-22 14:38:36.782 Z-Wave Debug . . getHomeID: 23727324, nodeID: 001
2015-05-22 14:38:36.783 Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
2015-05-22 14:38:36.785 Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 08 F7
2015-05-22 14:38:36.785 Z-Wave Debug . . getInterfaceFeatures: 08
2015-05-22 14:38:36.786 Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
2015-05-22 14:38:36.794 Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 7F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2
2015-05-22 14:38:36.853 Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
2015-05-22 14:38:36.854 Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
2015-05-22 14:38:36.855 Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
2015-05-22 14:38:36.864 Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 00 1D F1 ED FF 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 3F
2015-05-22 14:38:36.865 Z-Wave Debug . . getInitialNodeData: [1, 5, 6, 7, 8, 9, 11, 12, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29]
2015-05-22 14:38:36.866 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
2015-05-22 14:38:36.867 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 92 16 00 02 02 01 33
2015-05-22 14:38:36.868 Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
2015-05-22 14:38:36.868 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
2015-05-22 14:38:36.869 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2015-05-22 14:38:36.869 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2015-05-22 14:38:36.870 Z-Wave Debug . . getNodeProtocolInfo: features: beaming
2015-05-22 14:38:36.871 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
2015-05-22 14:38:36.871 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 10 01 ED
2015-05-22 14:38:36.872 Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Power Switch
2015-05-22 14:38:36.872 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
2015-05-22 14:38:36.873 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2015-05-22 14:38:36.873 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
2015-05-22 14:38:36.874 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
2015-05-22 14:38:36.876 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
2015-05-22 14:38:36.879 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 C9 04 00 03 10 00 68
2015-05-22 14:38:36.881 Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Relay Switch
2015-05-22 14:38:36.881 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Relay Switch : -- (03 : 10 : 00)
2015-05-22 14:38:36.882 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2015-05-22 14:38:36.883 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25
2015-05-22 14:38:36.883 Z-Wave Debug . . getNodeProtocolInfo: features: - none -
2015-05-22 14:38:36.884 Z-Wave found module included in controller with no matching device (missing or disabled): 006 - Relay Switch
2015-05-22 14:38:36.885 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
2015-05-22 14:38:36.885 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 C9 04 00 03 10 00 68
2015-05-22 14:38:36.886 Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Relay Switch
2015-05-22 14:38:36.886 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Relay Switch : -- (03 : 10 : 00)
2015-05-22 14:38:36.887 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2015-05-22 14:38:36.887 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25
2015-05-22 14:38:36.888 Z-Wave Debug . . getNodeProtocolInfo: features: - none -
2015-05-22 14:38:36.890 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
2015-05-22 14:38:36.893 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 C9 04 00 03 10 00 68
2015-05-22 14:38:36.894 Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Relay Switch
2015-05-22 14:38:37.022 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Relay Switch : -- (03 : 10 : 00)
2015-05-22 14:38:37.023 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2015-05-22 14:38:37.023 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25
2015-05-22 14:38:37.024 Z-Wave Debug . . getNodeProtocolInfo: features: - none -
2015-05-22 14:38:37.027 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
2015-05-22 14:38:37.030 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 C9 04 00 03 10 00 68
2015-05-22 14:38:37.032 Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: Relay Switch
2015-05-22 14:38:37.032 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Relay Switch : -- (03 : 10 : 00)
2015-05-22 14:38:37.033 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2015-05-22 14:38:37.034 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25
2015-05-22 14:38:37.034 Z-Wave Debug . . getNodeProtocolInfo: features: - none -
2015-05-22 14:38:37.037 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
2015-05-22 14:38:37.043 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 12 96 00 01 01 01 33
2015-05-22 14:38:37.044 Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Portable Remote Controller
2015-05-22 14:38:37.045 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01)
2015-05-22 14:38:37.046 Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
2015-05-22 14:38:37.046 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
2015-05-22 14:38:37.047 Z-Wave Debug . . getNodeProtocolInfo: features: beaming
2015-05-22 14:38:37.050 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0C B6
2015-05-22 14:38:37.054 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 C9 04 00 03 10 00 68
2015-05-22 14:38:37.055 Z-Wave Debug . . getNodeProtocolInfo: node 012, class name: Relay Switch
2015-05-22 14:38:37.055 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Slave : Relay Switch : -- (03 : 10 : 00)
2015-05-22 14:38:37.056 Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
2015-05-22 14:38:37.057 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25
2015-05-22 14:38:37.057 Z-Wave Debug . . getNodeProtocolInfo: features: - none -
2015-05-22 14:38:37.060 Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0E B4
2015-05-22 14:38:37.063 Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 52 9C 00 04 20 01 5D
2015-05-22 14:38:37.064 Z-Wave Debug . . getNodeProtocolInfo: node 014, class name: Binary Sensor (routing)
2015-05-22 14:38:37.065 Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
2015-05-22 14:38:37.065 Z-Wave Debug . . getNodeProtocolInfo: base class command: 30
2015-05-22 14:38:37.066 Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 30
2015-05-22 14:38:37.066 Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Fri May 22, 2015 1:44 pm
Hi Ted,
Thanks for the log information – that helps. I've added this one to our list of Z-Wave modules to investigate.
Mon Jun 15, 2015 8:15 am
tedco offline
Just checking back on this. Is there anything that I can do to help this along?
Ted
Mon Jun 15, 2015 9:57 am
Nope - we just need to schedule it for some upcoming release. No details at the moment.
Fri Aug 07, 2015 8:37 pm
tmacdon offline
I've just upgraded to the newest indigo 6 pro version. (I've been using previous versions for several years) It is great!
I eagerly tried to add my second z-wave module to my system (the linear garage door opener) and discovered that it isn't supported yet.
Is there any way for a user (me) to add new modules? If not, will this be supported soon or should I return the linear garage door opener?
Tim
Sun Aug 09, 2015 8:09 am
Hi Tim,
No, we have to add the device definitions. It is on our list and we will be investigating it soon.
Tue Aug 18, 2015 4:29 pm
manoncloud9 offline
I just got one of these as I keep having false readings from a grave sensor I have been using, Any ETA on this?
If not here is a Plus 1 to add it to the next release :-)
thanks
Joe
Tue Aug 18, 2015 4:32 pm
On our list, but we aren't giving out ETAs anymore. We end up spending too much time trying to manage communicate ETAs then.
Wed Aug 19, 2015 12:17 pm
manoncloud9 offline
Understand. Thanks for the response
Wed Aug 19, 2015 5:29 pm
Sharek326 offline
I have been using this with success for about a month now via Vera Plugin. Note that you have to be using UI7 on your vera for it to see it as a Garage Door. But I do look forward to it being supported in Indigo.
Mon Feb 01, 2016 5:41 am
Seeker offline
this devices is now under $50. is it supported yet?
http://slickdeals.net/f/8476481-zwave-g ... ?t=8476481
