Encouraged by this post I just got a brand new GD00Z-1 from Lowes. The sticker on the back reads
Date: 14247
H/W RevA
F/W Ver1.0
I am using the beta ZWave library and I have Indigo 7.0.3
I did follow the instructions from the post "by matt (support) » Wed Jul 05, 2017 1:08 pm"
It syncs but it won't respond to open/close request from the device panel.
This is the log from the sync
Oct 12, 2017, 20:45:41
Stopping interface Z-Wave (pid 551)
Z-Wave closed connection to Z-Stick Plus (ZW090)
Stopped interface Z-Wave
Upgrading interface Z-Wave to newer version 2.0.96 (previous version moved to trash)
Loading interface "Z-Wave 2.0.96"
Starting interface "Z-Wave 2.0.96" (pid 28893)
Started interface "Z-Wave 2.0.96"
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem26271 (firmware 1.00)
Z-Wave found module included in controller with no matching device (missing or disabled): 020 - Alarm Sensor (routing)
Oct 12, 2017, 20:48:00
Z-Wave started controller inclusion mode with encryption
Z-Wave controller included module: 048 - Secure Barrier Add-On
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave Lock Manager Debug Checking if node 48 is a Lock...
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Oct 12, 2017, 20:49:00
Z-Wave Syncing - started for "048 - Secure Barrier Add-On"
Z-Wave Syncing - retrieved module neighbors list: 2, 4, 10, 14, 15, 29, 45, 46
Z-Wave Syncing - assigning return route to "048 - Secure Barrier Add-On"
Z-Wave Syncing - retrieved manufacture and model names: LinearLinc - 014F, Garage Door Controller (GD00Z-4) - 47443030
Z-Wave Syncing - retrieved protocol version 3.67, app version 1.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07, base 66)
Z-Wave Syncing - retrieved command classes: 20v1 22v1 86v1 66v1 71v1 72v1 98v1 5Av1 85v1
Z-Wave Syncing - retrieved encrypt commands: 22 66 86 71 85
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
SQL Logger creating table device_history_259846048 for "048 - Garage Door Controller (GD00Z-4)"
Z-Wave Syncing - created device "048 - Garage Door Controller (GD00Z-4)"
Z-Wave Syncing - complete
Z-Wave sent "048 - Garage Door Controller (GD00Z-4)" status request
Z-Wave received "048 - Garage Door Controller (GD00Z-4)" status update is opening
This is from attempting to open and close the door
Oct 12, 2017, 20:50:19
Z-Wave sent "Garage Door Controller" close
Z-Wave received "Garage Door Controller" status update is stopped
Oct 12, 2017, 20:50:45
Z-Wave sent "Garage Door Controller" open
Oct 12, 2017, 20:51:00
Z-Wave sent "Garage Door Controller" status request
Oct 12, 2017, 20:51:16
Oct 12, 2017, 20:51:44
This is closing the door with debug on
Z-Wave Debug RCVD nonceFetch: node 048
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 4D 75 D5 C8 8A 6E 85 AD 25 26 35
Z-Wave Debug RCVD encryptedPacket: 00 66 03 FD (decrypted)
Z-Wave Debug RCVD requestBarrierStatus: 01 09 00 04 00 30 03 66 03 FD FF
Z-Wave Debug . . requestBarrierStatus: node 048, endpoint None, value 253
And this is a re-sync with debug on
Z-Wave Syncing - started for "Garage Door Controller"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 30 01 01 49
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 0A 62 00 10 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16
Z-Wave Debug . . getNodeNeighbors: nodeId 048, neighbors: 2, 4, 10, 14, 15, 29, 45, 46
Z-Wave Syncing - assigning return route to "048 - Garage Door Controller"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 30 01 8D
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 048, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 30 24 28 A5
Z-Wave Debug RCVD nodeInfoFrame: 01 0C 00 49 84 30 06 04 40 07 72 98 5A FB
Z-Wave Debug . . nodeInfoFrame: node 048, combined class list: 20v1 98v1 72v1 5Av1 66v1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 29 03
Z-Wave Debug RCVD nonceReport: node 048, nonce 72 CD 75 9C 3E 0B 1B 8D
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce F5 8F 22 66 99 A3 2D 0F (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 EC 0F 13 FD 30 FB 0C 9E 25 2B 85
Z-Wave Debug RCVD encryptedPacket: 00 98 03 00 86 66 22 71 85 EF (decrypted)
Z-Wave Debug RCVD requestEncryptedCmdClasses: 01 0F 00 04 00 30 09 98 03 00 86 66 22 71 85 EF FF
Z-Wave Debug RCVD requestEncryptedCmdClasses: node 048, classes 86 66 22 71 85 EF
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 30 02 72 04 25 2C A8
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 30 08 72 05 01 4F 47 44 30 30 F7
Z-Wave Debug . . requestManufactureInfo: node 048, manufacturerId 014F, productId 47443030
Z-Wave Debug . . requestManufactureInfo: LinearLinc, Garage Door Controller (GD00Z-4)
Z-Wave Debug SENT requestVersInfoGen: 86 11 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce 9E 72 88 91 27 0C CC 75 (saving)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 0A 0E 32 02 21 64 00 04 EE CC 00 3C 00 04 EE CC A2
Z-Wave Debug . . requestMeterLevel: node 010, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 323.276 kWh (float: 323.276000)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 2E 04
Z-Wave Debug RCVD nonceReport: node 048, nonce 2C C6 E3 A2 29 A5 04 E1
Z-Wave Debug RCVD nonceReport: node 048, nonce B0 E8 26 C7 0B B6 23 10 (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 C2 32 C5 D6 3E 8F 30 8A 25 30 22
Z-Wave Debug RCVD encryptedPacket: 00 86 12 03 03 43 01 00 01 01 00 00 (decrypted)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 30 0B 86 12 03 03 43 01 00 01 01 00 00 FF
Z-Wave Debug . . requestVersInfoGen: node 048, protoVers 3.67, appVers 1.00
Z-Wave Syncing - retrieved encrypt commands: 22 85 66 71 86
Z-Wave Debug SENT requestAssociationGroupCount: 85 05 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce 69 6D 40 73 05 F5 10 A8 (saving)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 02 0E 32 02 21 64 00 00 A3 4B 00 3C 00 00 A3 4B AA
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 41.803 kWh (float: 41.803000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 02 0E 32 02 21 74 00 00 00 54 00 3C 00 00 A3 4B 06
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.084 W (float: 0.084000)
Z-Wave received "Washer Switch" power load to 0.084 W
Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 02 08 31 05 04 64 00 00 00 54 FF
Z-Wave Debug . . requestVarSensorStatus: node 002, endpoint None, type 4, raw value 6400...
Z-Wave Debug . . requestVarSensorStatus: 0.084 W (float: 0.084000)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 32 18
Z-Wave Debug RCVD nonceReport: node 048, nonce AA 5F B8 C9 83 13 C0 FB
Z-Wave Debug RCVD nonceReport: node 048, nonce 4C F4 7E 80 0E 3A E0 FE (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 8C BB 37 AA 27 FF 24 51 25 34 C9
Z-Wave Debug RCVD encryptedPacket: 00 85 06 01 (decrypted)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 30 03 85 06 01 FF
Z-Wave Debug . . requestAssociationGroupCount: node 048, group count: 1
Z-Wave Debug SENT requestAssociations: 85 02 01 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce C7 12 30 35 B9 50 24 0F (saving)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 36 1C
Z-Wave Debug RCVD nonceReport: node 048, nonce 1B 2C 1C CB F0 A8 AE F7
Z-Wave Debug RCVD nonceReport: node 048, nonce E5 C1 F0 51 06 BF B7 48 (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 25 B6 CC CA 48 33 C7 4E 25 38 A5
Z-Wave Debug RCVD encryptedPacket: 00 85 03 01 01 00 (decrypted)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 30 05 85 03 01 01 00 FF
Z-Wave Debug . . requestAssociations: node 048, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 048, group: 1, associations: []
Z-Wave Debug SENT addInterfaceAssociation: 85 01 01 01 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce A4 C0 B6 16 BA 5E 70 26 (saving)
Z-Wave Debug . . addInterfaceAssociation: node 048, group: 1, associations: [1]
Z-Wave Debug SENT requestBarrierStatus: 66 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce 1E 6E 0B C5 6B 73 3D CC (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 25 B6 CC CA 48 33 C7 4E 25 3B A6
Z-Wave Debug terminatingSyncUI
