[ANSWERED]: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Opener
Thu Oct 12, 2017 10:05 pm
rom1011 offline
Re: [ANSWERED]: Linear GD00Z-4 GD00Z-4 Z-Wave Garage Door Op
Encouraged by this post I just got a brand new GD00Z-1 from Lowes. The sticker on the back reads
Date: 14247
H/W RevA
F/W Ver1.0
I am using the beta ZWave library and I have Indigo 7.0.3
I did follow the instructions from the post "by matt (support) » Wed Jul 05, 2017 1:08 pm"
It syncs but it won't respond to open/close request from the device panel.
This is the log from the sync
Oct 12, 2017, 20:45:41
Stopping interface Z-Wave (pid 551)
Z-Wave closed connection to Z-Stick Plus (ZW090)
Stopped interface Z-Wave
Upgrading interface Z-Wave to newer version 2.0.96 (previous version moved to trash)
Loading interface "Z-Wave 2.0.96"
Starting interface "Z-Wave 2.0.96" (pid 28893)
Started interface "Z-Wave 2.0.96"
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem26271 (firmware 1.00)
Z-Wave found module included in controller with no matching device (missing or disabled): 020 - Alarm Sensor (routing)
Oct 12, 2017, 20:48:00
Z-Wave started controller inclusion mode with encryption
Z-Wave controller included module: 048 - Secure Barrier Add-On
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave Lock Manager Debug Checking if node 48 is a Lock...
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Oct 12, 2017, 20:49:00
Z-Wave Syncing - started for "048 - Secure Barrier Add-On"
Z-Wave Syncing - retrieved module neighbors list: 2, 4, 10, 14, 15, 29, 45, 46
Z-Wave Syncing - assigning return route to "048 - Secure Barrier Add-On"
Z-Wave Syncing - retrieved manufacture and model names: LinearLinc - 014F, Garage Door Controller (GD00Z-4) - 47443030
Z-Wave Syncing - retrieved protocol version 3.67, app version 1.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07, base 66)
Z-Wave Syncing - retrieved command classes: 20v1 22v1 86v1 66v1 71v1 72v1 98v1 5Av1 85v1
Z-Wave Syncing - retrieved encrypt commands: 22 66 86 71 85
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
SQL Logger creating table device_history_259846048 for "048 - Garage Door Controller (GD00Z-4)"
Z-Wave Syncing - created device "048 - Garage Door Controller (GD00Z-4)"
Z-Wave Syncing - complete
Z-Wave sent "048 - Garage Door Controller (GD00Z-4)" status request
Z-Wave received "048 - Garage Door Controller (GD00Z-4)" status update is opening
This is from attempting to open and close the door
Oct 12, 2017, 20:50:19
Z-Wave sent "Garage Door Controller" close
Z-Wave received "Garage Door Controller" status update is stopped
Oct 12, 2017, 20:50:45
Z-Wave sent "Garage Door Controller" open
Oct 12, 2017, 20:51:00
Z-Wave sent "Garage Door Controller" status request
Oct 12, 2017, 20:51:16
Oct 12, 2017, 20:51:44
This is closing the door with debug on
Z-Wave Debug RCVD nonceFetch: node 048
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 4D 75 D5 C8 8A 6E 85 AD 25 26 35
Z-Wave Debug RCVD encryptedPacket: 00 66 03 FD (decrypted)
Z-Wave Debug RCVD requestBarrierStatus: 01 09 00 04 00 30 03 66 03 FD FF
Z-Wave Debug . . requestBarrierStatus: node 048, endpoint None, value 253
And this is a re-sync with debug on
Z-Wave Syncing - started for "Garage Door Controller"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 30 01 01 49
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 0A 62 00 10 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16
Z-Wave Debug . . getNodeNeighbors: nodeId 048, neighbors: 2, 4, 10, 14, 15, 29, 45, 46
Z-Wave Syncing - assigning return route to "048 - Garage Door Controller"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 30 01 8D
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 048, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 30 24 28 A5
Z-Wave Debug RCVD nodeInfoFrame: 01 0C 00 49 84 30 06 04 40 07 72 98 5A FB
Z-Wave Debug . . nodeInfoFrame: node 048, combined class list: 20v1 98v1 72v1 5Av1 66v1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 29 03
Z-Wave Debug RCVD nonceReport: node 048, nonce 72 CD 75 9C 3E 0B 1B 8D
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce F5 8F 22 66 99 A3 2D 0F (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 EC 0F 13 FD 30 FB 0C 9E 25 2B 85
Z-Wave Debug RCVD encryptedPacket: 00 98 03 00 86 66 22 71 85 EF (decrypted)
Z-Wave Debug RCVD requestEncryptedCmdClasses: 01 0F 00 04 00 30 09 98 03 00 86 66 22 71 85 EF FF
Z-Wave Debug RCVD requestEncryptedCmdClasses: node 048, classes 86 66 22 71 85 EF
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 30 02 72 04 25 2C A8
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 30 08 72 05 01 4F 47 44 30 30 F7
Z-Wave Debug . . requestManufactureInfo: node 048, manufacturerId 014F, productId 47443030
Z-Wave Debug . . requestManufactureInfo: LinearLinc, Garage Door Controller (GD00Z-4)
Z-Wave Debug SENT requestVersInfoGen: 86 11 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce 9E 72 88 91 27 0C CC 75 (saving)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 0A 0E 32 02 21 64 00 04 EE CC 00 3C 00 04 EE CC A2
Z-Wave Debug . . requestMeterLevel: node 010, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 323.276 kWh (float: 323.276000)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 2E 04
Z-Wave Debug RCVD nonceReport: node 048, nonce 2C C6 E3 A2 29 A5 04 E1
Z-Wave Debug RCVD nonceReport: node 048, nonce B0 E8 26 C7 0B B6 23 10 (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 C2 32 C5 D6 3E 8F 30 8A 25 30 22
Z-Wave Debug RCVD encryptedPacket: 00 86 12 03 03 43 01 00 01 01 00 00 (decrypted)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 30 0B 86 12 03 03 43 01 00 01 01 00 00 FF
Z-Wave Debug . . requestVersInfoGen: node 048, protoVers 3.67, appVers 1.00
Z-Wave Syncing - retrieved encrypt commands: 22 85 66 71 86
Z-Wave Debug SENT requestAssociationGroupCount: 85 05 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce 69 6D 40 73 05 F5 10 A8 (saving)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 02 0E 32 02 21 64 00 00 A3 4B 00 3C 00 00 A3 4B AA
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 41.803 kWh (float: 41.803000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 02 0E 32 02 21 74 00 00 00 54 00 3C 00 00 A3 4B 06
Z-Wave Debug . . requestMeterLevel: node 002, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.084 W (float: 0.084000)
Z-Wave received "Washer Switch" power load to 0.084 W
Z-Wave Debug RCVD requestVarSensorStatus: 01 0E 00 04 00 02 08 31 05 04 64 00 00 00 54 FF
Z-Wave Debug . . requestVarSensorStatus: node 002, endpoint None, type 4, raw value 6400...
Z-Wave Debug . . requestVarSensorStatus: 0.084 W (float: 0.084000)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 32 18
Z-Wave Debug RCVD nonceReport: node 048, nonce AA 5F B8 C9 83 13 C0 FB
Z-Wave Debug RCVD nonceReport: node 048, nonce 4C F4 7E 80 0E 3A E0 FE (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 8C BB 37 AA 27 FF 24 51 25 34 C9
Z-Wave Debug RCVD encryptedPacket: 00 85 06 01 (decrypted)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 30 03 85 06 01 FF
Z-Wave Debug . . requestAssociationGroupCount: node 048, group count: 1
Z-Wave Debug SENT requestAssociations: 85 02 01 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce C7 12 30 35 B9 50 24 0F (saving)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 30 02 98 40 25 36 1C
Z-Wave Debug RCVD nonceReport: node 048, nonce 1B 2C 1C CB F0 A8 AE F7
Z-Wave Debug RCVD nonceReport: node 048, nonce E5 C1 F0 51 06 BF B7 48 (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 25 B6 CC CA 48 33 C7 4E 25 38 A5
Z-Wave Debug RCVD encryptedPacket: 00 85 03 01 01 00 (decrypted)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 30 05 85 03 01 01 00 FF
Z-Wave Debug . . requestAssociations: node 048, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 048, group: 1, associations: []
Z-Wave Debug SENT addInterfaceAssociation: 85 01 01 01 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce A4 C0 B6 16 BA 5E 70 26 (saving)
Z-Wave Debug . . addInterfaceAssociation: node 048, group: 1, associations: [1]
Z-Wave Debug SENT requestBarrierStatus: 66 02 (encrypted)
Z-Wave Debug RCVD nonceReport: node 048, nonce 1E 6E 0B C5 6B 73 3D CC (saving)
Z-Wave Debug SENT nonceReport: 01 11 00 13 30 0A 98 80 25 B6 CC CA 48 33 C7 4E 25 3B A6
Z-Wave Debug terminatingSyncUI
Fri Oct 13, 2017 10:25 am
rom1011 offline
Actually I take it all back., It's working beautifully!
I wanted to be able to return the box if it did not work out so I only hooked up the controller but left the tilt sensor in the box. After connecting the tilt sensor it works like a charm.
Great work Indigo Team.
Fri Oct 13, 2017 3:56 pm
Great – glad you got it up and working!
Sat Nov 25, 2017 4:12 pm
stoney offline
I just installed my second garage door opener z-wave controller. It's exactly the same specs as my 1st one:
Date 17114
H/W Rev B
F/W Ver 2.1
See my previous post
The main difference from when I installed the first one is that I am now running Indigo 7.1.
It took dozens of tries to include it, using encryption. Once it was included, it failed to sync. I tried that dozens of times too. I reset the GDO and have not been able to include it again, after a dozen tries. I used the procedure Matt described.
I have several Z-Wave repeaters. I tried moving them around to see if it made a difference, but no.
My first GDO device still works fine.
Here are some log excerpts:
Failed device inclusion:
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug SENT enterInclusionMode: 01 04 00 4A C1 70
Z-Wave Debug RCVD enterInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 01 01 00 00 B2
nothing is logged when I push the button on the GDO.
The one successful inclusion:
Nov 25, 2017 at 3:49:09 PM
Nov 25, 2017 at 3:49:38 PM
Z-Wave controller included module: 007 - Secure Barrier Add-On
Unsuccessful Sync:
Nov 25, 2017 at 4:10:55 PM
Z-Wave Syncing - started for "007 - Secure Barrier Add-On"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 07 01 01 7E
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 26 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 78
Z-Wave Debug . . getNodeNeighbors: nodeId 007, neighbors: 2, 3, 6
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 6
Z-Wave Syncing - assigning return route to "007 - Secure Barrier Add-On"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 07 01 BA
Z-Wave Debug . . assignReturnRoute: node 007, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 07 24 58 E2
Z-Wave Debug RCVD nodeInfoFrame: 01 0E 00 49 84 07 08 04 40 07 5E 5A 72 73 98 ED
Z-Wave Debug . . nodeInfoFrame: node 007, combined class list: 20v1 66v1 72v1 73v1 98v1 5Av1 5Ev1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 07 02 98 40 25 59 44
Z-Wave Debug RCVD nonceReport: node 007, nonce 04 34 0F 0E 61 1D 29 AA
Z-Wave Debug RCVD nonceReport: node 007, nonce F5 96 86 5D E0 24 26 D4 (saving)
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 07 02 72 04 25 5B E8
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 07 08 72 05 01 4F 47 44 35 30 C5
Z-Wave Debug . . requestManufactureInfo: node 007, manufacturerId 014F, productId 47443530
Z-Wave Debug . . requestManufactureInfo: LinearLinc, Garage Door Controller (NGD00Z)
Z-Wave Syncing - retrieved manufacture and model names: LinearLinc - 014F, Garage Door Controller (NGD00Z) - 47443530
Z-Wave Debug SENT nonceRequest: 01 09 00 13 07 02 98 40 25 5C 41
Z-Wave Debug RCVD nonceReport: node 007, nonce 84 3C 3A 1D 12 60 AA 15
Z-Wave Debug RCVD nonceReport: node 007, nonce 9C 4A 24 8A BC 16 6F 83 (saving)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 07 02 98 40 25 5E 43
Z-Wave Debug RCVD nonceReport: node 007, nonce 25 40 3E A0 66 C1 5A DD
Z-Wave Debug RCVD nonceReport: node 007, nonce B0 E8 F9 A9 F3 83 90 DC (saving)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 07 02 98 40 25 60 7D
Z-Wave Debug RCVD nonceReport: node 007, nonce 61 FE 0E 1B 0D 41 24 27
Z-Wave Debug RCVD nonceReport: node 007, nonce 02 DB 29 58 F5 90 3F 8D (saving)
Z-Wave Debug maximum retry count exceeded waiting reply from module
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "007 - Secure Barrier Add-On". Module might be asleep, or is unreachable.
I'm unsure whether this could be caused by the new Z-Wave support in 7.1 or something else.
Any ideas?
Sat Nov 25, 2017 6:48 pm
Sharek326 offline
I have tried for months to get this unit to work following all the steps that so many others used to get it to work. I have finally given up and just use it with Vera
Sun Nov 26, 2017 4:26 pm
Date 17114
H/W Rev B
F/W Ver 2.1
Nothing was changed (intentionally at least) in 7.1 with regards to how Indigo handles this module or Z-Wave inclusion/syncing with encrypted devices. Your logs look like the module is either marginal or there is a signal problem reliably reaching it. I'd suggest wiring it up next to your Mac, then resetting it and following the full list of steps you did previously to see if that gets it working. If not, I think it is marginal and you should try a replacement.
Let us know how it goes...
Sat Mar 10, 2018 5:51 pm
Sharek326 offline
After nearly two years of trying to get this device to work I think I finally solved my problem. Today I switched out my Gen2 Z-Wave stick for a Gen5. After I got everything running I decided to give the Garage Door another shot. Synced first try. I think the problem all along way the stick.
Sat Apr 28, 2018 2:48 pm
brianlloyd offline
Matt's instructions solved the problem for me too. Thanks Matt!
Sun Feb 17, 2019 5:07 pm
johnfdl offline
So my GD00Z-4 stopped working. I tried everything, but to no avail. It would attempt to control the garage door (as when I clicked off, it would beep as if it was about to close the door) but it just never actually would do anything. So I effectively ruled out Indigo as Indigo accurately issued the commands and read the status of the door accurately.
So I went on Amazon and found this is apparently a pretty common problem. It just stops controlling the door after a period of time. Wanted to post this here so others know.
I ordered another on Amazon and paired it using Matt's instructions, which paired/sync'd but it didn't appear to control anything (I'd issue an off command and it would not beep or anything. Then I manually closed the garage door with the wired button attached to the motor and after that, it worked flawlessly. Unsure how long this one will last.....we'll see.
Hope this helps.
