Hi
I am a new user of Indigo, trying to get it working for the first time.
Just to test I use only one device + an interface: the Z-Wave.me UZB1 together with Aeotec Smart Switch Gen5. I successfully included the Smart Switch using an other software (Zensys tools), but back in Indigo I get trouble: The switch is not reacting. (It don't turn on and off.) At the same time Indigo reacts as everything works: The 'State' in Indigo tells 'on' and 'off', which is kind of misleading.
The switch is recognized but don't return any ACK:
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 0C 03 25 01 00 05 0C C4
Z-Wave sent "012 - Relay Power Switch" off
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 0C 03 25 01 FF 05 0D 3A
Z-Wave sent "012 - Relay Power Switch" on
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 0C 03 25 01 00 05 0E C6
If I remove the switch from the outlet. I get error messages:
Z-Wave Debug RCVD setRelayValue: 01 07 00 13 0E 01 00 18 FC (node NAK)
Z-Wave Error send "012 - Relay Power Switch" off failed
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 0C 03 25 01 FF 05 0F 38
Z-Wave Debug RCVD setRelayValue: 01 07 00 13 0F 01 00 0B EE (node NAK)
Z-Wave Error send "012 - Relay Power Switch" on failed
So, after reading the list of supported hardware, I might think maybe the switch isn't supported at all. Is that the case? Is it not possible to use this switch?
