wideglidejrp wrote:Does this device work with Indigo? I am in a bad way. My WiFi vibration sensor failed and are not made any longer. I have been waiting more than a year for the MS6. I have to do something. Either Vision Shock Sensor or any other suggestions will be greatly appreciated.
Z-Wave received "Shock sensor" status update is on
Z-Wave received "Shock sensor" status update is off
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 74 03 20 01 FF 5B
Z-Wave Debug . . sensorSetLevel: node 116, endpoint None, cmdClass 20, value 255
Z-Wave received "Shock sensor 1" status update is on
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 74 09 71 05 02 FF 00 FF 07 02 00 FA
Z-Wave Debug . . requestAlarmSensorStatus: node 116, endpoint None, cmdClass 71, type 2, value 255, classSubKey 7102FF
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 2, classSubKeyExt 7102FF0702
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 74 03 20 01 00 A4
Z-Wave Debug . . sensorSetLevel: node 116, endpoint None, cmdClass 20, value 0
Z-Wave received "Shock sensor 1" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 74 0A 71 05 02 00 00 FF 07 00 01 02 18
Z-Wave Debug . . requestAlarmSensorStatus: node 116, endpoint None, cmdClass 71, type 2, value 0, classSubKey 710200
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7102000700
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 78 03 20 01 00 A8
Z-Wave Debug . . sensorSetLevel: node 120, endpoint None, cmdClass 20, value 0
Z-Wave received "Shock sensor 2" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 78 0A 71 05 02 00 00 FF 07 00 01 02 14
Z-Wave Debug . . requestAlarmSensorStatus: node 120, endpoint None, cmdClass 71, type 2, value 0, classSubKey 710200
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 78 03 20 01 FF 57
Z-Wave Debug . . sensorSetLevel: node 120, endpoint None, cmdClass 20, value 255
Z-Wave received "Shock sensor 2" status update is on
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 78 09 71 05 02 FF 00 FF 07 02 00 F6
Z-Wave Debug . . requestAlarmSensorStatus: node 120, endpoint None, cmdClass 71, type 2, value 255, classSubKey 7102FF
Z-Wave Debug RCVD basicReportState: 01 09 00 04 00 0F 03 20 03 FF 22
Z-Wave Debug . . basicReportState: node 015, endpoint None, value 255 (no node dispatch)
