- Posted on
Fri Mar 13, 2015 4:52 am
Coolcaper
offline
Hi Matt, below is the log with debugging turned on. Thanks jenwill1; tried your method as well, no luck:
Z-Wave Debug stopping node status polling
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
Z-Wave Debug . . getVersion: Z-Wave 2.78 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 01 61 D3 31 01 55
Z-Wave Debug . . getHomeID: 23188273, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 08 F7
Z-Wave Debug . . getInterfaceFeatures: 08
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 3F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 82
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 00 1D FF FF 7F FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 43
Z-Wave Debug . . getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 25, 26, 27, 28, 29, 30, 31, 32]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 12 16 00 01 02 00 B1
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Controller : Static Controller : -- (01 : 02 : 00)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave found module included in controller with no matching device (missing or disabled): 001 - Indigo Z-Wave Interface
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 20 01 5D
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Binary Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 30
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 30
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 52 9C 00 04 20 01 5D
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 003 type from zwOnOffSensorType to zwValueSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 004, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 006 type from zwOnOffSensorType to zwValueSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 20 01 5C
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 008 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 009 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0A B0
Z-Wave Debug . . getNodeProtocolInfo: node 010, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 010 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 0F 01 F3
Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Basic Repeater Slave
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Repeater Slave : Basic Repeater Slave (04 : 0F : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0C B6
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 11 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 012, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0D B7
Z-Wave Debug . . getNodeProtocolInfo: node 013, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0E B4
Z-Wave Debug . . getNodeProtocolInfo: node 014, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0F B5
Z-Wave Debug . . getNodeProtocolInfo: node 015, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 015 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 10 AA
Z-Wave Debug . . getNodeProtocolInfo: node 016, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 016 type from zwOnOffSensorType to zwValueSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 11 AB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 017, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 12 A8
Z-Wave Debug . . getNodeProtocolInfo: node 018, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 018 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 13 A9
Z-Wave Debug . . getNodeProtocolInfo: node 019, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 14 AE
Z-Wave Debug . . getNodeProtocolInfo: node 020, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 020 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 15 AF
Z-Wave Debug . . getNodeProtocolInfo: node 021, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 16 AC
Z-Wave Debug . . getNodeProtocolInfo: node 022, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 17 AD
Z-Wave Debug . . getNodeProtocolInfo: node 023, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 19 A3
Z-Wave Debug . . getNodeProtocolInfo: node 025, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1A A0
Z-Wave Debug . . getNodeProtocolInfo: node 026, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1B A1
Z-Wave Debug . . getNodeProtocolInfo: node 027, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1C A6
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D2 9C 00 04 20 01 DD
Z-Wave Debug . . getNodeProtocolInfo: node 028, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 028 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1D A7
Z-Wave Debug . . getNodeProtocolInfo: node 029, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1E A4
Z-Wave Debug . . getNodeProtocolInfo: node 030, class name: Binary Sensor (routing)
Z-Wave Debug overriding node 030 type from zwOnOffSensorType to zwOnOffSensorType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 1F A5
Z-Wave Debug . . getNodeProtocolInfo: node 031, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 20 9A
Z-Wave Debug . . getNodeProtocolInfo: node 032, class name: Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 032 - Binary Sensor (routing)
Z-Wave Debug starting node status polling
Z-Wave Debug intiatingSyncUI (timeout in 300 seconds)
Z-Wave Syncing - started for device "032 - Binary Sensor (routing)"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 20 01 01 59
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 58 3C 45 57 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28
Z-Wave Debug . . getNodeNeighbors: nodeId 032, neighbors: 4, 5, 7, 11, 12, 13, 14, 17, 19, 23, 25, 26, 27, 29, 31
Z-Wave Syncing - retrieved module neighbors list: 4, 5, 7, 11, 12, 13, 14, 17, 19, 23, 25, 26, 27, 29, 31
Z-Wave Syncing - requesting neighbor list update of "032 - Binary Sensor (routing)"
Z-Wave Debug SENT requestNeighborUpdate: 01 04 00 48 20 93
Z-Wave Debug RCVD requestNeighborUpdate: 06 (ACK)
Z-Wave Debug RCVD requestNeighborUpdate: 01 05 00 48 01 21 92
Z-Wave Debug . . requestNeighborUpdate: node 032, update starting
13 Mar 2015 6:39:44 pm
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 08 1C 06 31 05 03 0A 00 06 DE
Z-Wave Debug . . requestVarSensorStatus: node 028, endpoint None, type 3, raw value 0A00...
Z-Wave Debug . . requestVarSensorStatus: 6 lux (float: 6.000000)
Z-Wave received "Porch Luminance" sensor update to 6 lux
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 1C 06 31 05 03 0A 00 06 D6
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 08 1C 06 31 05 05 01 26 00 F3
Z-Wave Debug . . requestVarSensorStatus: node 028, endpoint None, type 5, raw value 0126...
Z-Wave Debug . . requestVarSensorStatus: 38% (float: 38.000000)
Z-Wave received "Porch Humidity" sensor update to 38%
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 1C 06 31 05 05 01 26 00 FB
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 08 1C 06 31 05 01 22 01 0B F8
Z-Wave Debug . . requestVarSensorStatus: node 028, endpoint None, type 1, raw value 2201...
Z-Wave Debug . . requestVarSensorStatus: 26.7 °C (float: 26.700000)
Z-Wave received "Porch Temperature" sensor update to 26.7 °C
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 1C 06 31 05 01 22 01 0B F0
13 Mar 2015 6:40:29 pm
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 14 03 20 01 00 C4
Z-Wave Debug . . sensorSetLevel: node 020, endpoint None, cmdClass 20, value 0
Z-Wave received "Dining Sensor" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 14 0A 71 05 07 00 00 FF 07 02 00 00 7C
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 08 03 20 01 00 D8
Z-Wave Debug . . sensorSetLevel: node 008, endpoint None, cmdClass 20, value 0
Z-Wave received "Living Sensor" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 08 0A 71 05 07 00 00 FF 07 02 00 00 60
13 Mar 2015 6:42:00 pm
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 08 1C 03 20 01 00 C4
Z-Wave Debug . . sensorSetLevel: node 028, endpoint None, cmdClass 20, value 0
Z-Wave received "Porch Motion Sensor" status update is off
Z-Wave Debug . . dimmerAssocSetLevel: cmd class 20, node 025, value 0
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 1C 03 20 01 00 CC
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 19 03 26 03 00 CD
Z-Wave Debug . . requestDimmerStatus: node 025, endpoint None, value 0
WUnderground Getting weather data for device: Weather
WUnderground Weather Underground data parsed successfully.
13 Mar 2015 6:44:07 pm
Z-Wave Debug terminatingSyncUI
13 Mar 2015 6:47:13 pm
Z-Wave Error Timeout waiting for "032 - Binary Sensor (routing)". Module might be asleep, or is unreachable.
Z-Wave Debug terminatingSyncUI (ignoring -- insideSyncUiCount value is already 0)
13 Mar 2015 6:47:38 pm
SQL Logger deleting table device_history_805470955
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 01 98
Z-Wave Debug RCVD requestHasNodeFailed: 01 04 01 62 00 98
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 02 9B
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 03 9A
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 04 9D
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 05 9C
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 06 9F
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 07 9E
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 08 91
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 09 90
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 0A 93
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 0B 92
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 0C 95
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 0D 94
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 0E 97
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 0F 96
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 10 89
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 11 88
Z-Wave Error failed to remove module 017 from controller ()
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 11 88 (re-sent because no response)
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 12 8B
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 13 8A
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 14 8D
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 15 8C
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 16 8F
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 17 8E
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 19 80
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1A 83
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1B 82
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1C 85
Z-Wave Error rcvd incomplete interface packet (skipping): 01 04 01 62 00
Z-Wave Error failed to remove module 028 from controller ()
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1C 85 (re-sent because no response)
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1D 84
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1E 87
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 1F 86
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 20 B9
Z-Wave no failed modules found in controller
