- Code: Select all
Z-Wave Debug SENT requestHasNodeFailed: 01 04 00 62 20 B9
Z-Wave Debug RCVD requestHasNodeFailed: 01 04 01 62 00 98
show that the Z-Stick is responding that node 032 (20 in hex) is not in the failed state in the Z-Stick. If it were in the failed state the last 2 bytes of the second line would be 01 98 instead of 00 98. I'm not sure why the Z-Stick thinks the node is still okay, even after the sync against it obviously fails.
Unfortunately, aside from totally resetting your Z-Stick which would require that you exclude and re-include all the modules, I'm not sure what to suggest. It appears the Z-Stick is in a slightly confused state, but it is probably not worth resetting it given the number of modules you have.
