matt (support) wrote:...
Unfortunately, I don't believe there is any way to do this in Indigo (even using raw Z-Wave commands). It is going to require additional work in the internal Z-Wave library we use, as well as changes to Indigo's model definition for the Fibaro RGBW and UI changes.
I've found the FGRGBW to be a very useful device. I initially used it for kitchen cabinets, but then added another to light the interior of an antique display cabinet with perfect results. I needed to be able to have different level of lighting for different shelves and the module was perfect for that. Since then, last year I constructed some built-ins around the fireplace and lit those (with an extra channel for the Christmas decorations) and now I'm finishing up a set of Library built-ins also with lighting that I can adjust individually across the rows of shelves - brighter lights on the upper shelves where display items are, and less at the lower shelves, with a script to bring up night-light levels at appropriate times. The only down side is that my wife is beginning to expect me to perform miracles.
I've been patiently waiting for the wish-list of reading the inputs back from the module.......
So is there any progress toward those aforementioned changes in the library, model definition and (I guess we would have seen them) UI ?
If the MIMOlite is supported, doesn't that in some ways give you the UI functions needed?
Jack
