Umtauscher wrote:I would expect there would at least be support for a device that is certified by the z-wave alliance in a acceptable time frame.
There is a misconception of what the Z-Wave certification process means in regards to how "easy" it is to support a device. It certifies that the lower level command classes work as they should (although we've found problems we still have to work around), but it isn't enough to automate the definition of a higher level end-user usable device (for complex devices). That requires work from us, and when it is a more complex device (not just a dimmer or switch relay), it can require a significant amount of work. We are looking at ways to enable support for more complex devices that we haven't yet created definitions for, although it is complicated and the end user result wouldn't be the typical intuitive Indigo device collection.
I wonder how many other control hubs support this particular device. Based on my searches it doesn't look like many. It looks like it might work on some models of Vera and, of course, it works on the ZipaBox (Zipato's hub). But...
Not on Samsung SmartThings:
https://community.smartthings.com/t/hel ... eypad/5867Not on HomeSeer:
http://board.homeseer.com/showthread.ph ... ost1237489And from what I can tell it also does not work with the Lowe's Iris, Nexia Bridge, Staples Connect, Wink, or openHAB. So it works on about 2 of the 8 more popular hubs, one of which is from the same manufacturer.
That isn't because all the control hub companies have attitudes, but because adding devices requires development and QA time, often significantly more than one would think, and those resources are always limited.
Umtauscher wrote:How should someone consider buying new z-wave equipment?
I would consult our device list and, if it isn't there, then search and post on the on the forum to see if anyone has reported success with it. If not, post a request on the forum.
I'm sorry if you think our attitude is unprofessional, but we aren't going to promise we can deliver support for all Z-Wave devices when that isn't likely to happen. We are trying to be professional and honest. We will continue to add support for popular Z-Wave devices, but that requires us to prioritize both the demand for the device and the difficulty in supporting it. We no longer provide time estimates as to when devices will be supported, but we are actively working on the next major version of Indigo. And once Indigo 7 is released we will be cranking out more timely releases with additional device support.
