I'm updating this in case someone comes looking...
The Smart Strip pairs fine with Indigo (as expected), and shows 4 x outlets in tabs, the first time you add the device. Each tab becomes an individual device in Indigo, as you update the 4 x tabs, and each outlet can be individually controlled. Each device in Indigo reports power and each devices power usage is individually resettable. There is no "master" device displayed and I saw no method to turn all 4 x outlets on/off, like the button on the strip does. I have very low power devices on the ports, so I'm not sure if any or all of the power reports are individual outlets or combined outlets. I'll update as I determine this.
Now to my question...
I have a GE Portable Controller that Indigo adds just fine (
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/45631-Manual-Eng.pdf). The controller supports groups and scenes (4 each). To add a device to a group or scene, you put the controller in add mode, select scene or group & the on button for selection 1-4. Then you go to the device and press the "pairing" button on the device. This is where my issue comes in. The Smart Strip pairing button turns ALL 4 x outlets off/on at the same time. With this method, I can't add an individual outlet to a group or scene. Any ideas? I've also sent a support request to AEOTEC (AEON Labs).
Ps. Using either group or scene, Indigo does not see the activity when the button is pressed on the controller. The activity (scene or group on/off) works, and the only thing Indigo sees is if the devices affected report an update. I'm not sure if this is relevant, and I plan to make another post regarding this.
Frank
