- Posted on
Thu May 22, 2014 7:29 am
McJohn
offline
Hi Matt,
Thanks for the fast reply.
For example: yesterday evening I synced the new Aeon Recessed Door Sensor (DSB54).
I don't use a repeater because I think the range of the modules is good enough.
(except some issues with my metal garage door and even a strange low battery issue with this Everspring sensor)
All the modules are working good, even with Skip finding neighbor nodes, some are 55 feet from the Aeon stick, outside of my house.
I just did a re-synced from the DSB54;
Below the log. The sync time was 1 minute and 46 seconds.
See also the strange battery messages.... (the Device info displays 100% battery level)
Thanks and greetings,
John
22 mei 2014 15:18:00
Z-Wave Syncing - started for device ”Door Garden”
Z-Wave Syncing - retrieved module neighbors list: 1, 9, 11, 15, 16, 17, 18, 22, 25, 27, 38, 41, 43, 45, 48, 54
Z-Wave Syncing - requesting neighbor list update of "058 - Door Garden”
22 mei 2014 15:18:23
Z-Wave Syncing - retrieved battery level of 45%
Z-Wave Syncing - assigning return route to "058 - Door Garden”
22 mei 2014 15:19:24
Z-Wave Syncing - retrieved battery level of 72%
Z-Wave Error Timeout waiting for "058 - Door Garden". Module might be asleep, or is unreachable.
22 mei 2014 15:24:39
Z-Wave Indigo Device "Door Garden" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.232
Node ID: 58
Model: Recessed Door Sensor (DSB54)
Model ID: 00020036
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.67
Application Version: 1.05
Model Definition Version: 1
Library Type: 3
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 72v1
Features: routing, battery, beaming, waking
Neighbors: 1, 11, 15, 16, 17, 18, 25, 38, 54
Associations: 1:[1] 2:[]
Config Values: - none -
- Schermafbeelding 2014-05-22 om 15.26.50.png (23.2 KiB) Viewed 2769 times
