I just installed one of these. Included it as a secure device. Sensor is calibrated and reports correct open/close/opening/closing. I've associated it with a Fibaro Keyfob and that works as well.
What I can't get working is controlling it from a Fibaro Dimmer 2. I've re-included the fibaro dimmer in secure mode and associated the garage door controller to group 4, but can't get that to control the garage door. I then tried to create a trigger to send
20 01 FF as raw command to the garage door controller, but that does also not work.
Log for normal On/Off sequence from Indigo,which works fine:
- Code: Select all
Z-Wave Watcher Debug Raw command sent (Node 19): 01 09 00 13 13 02 98 40 25 8D 84 (True)
Z-Wave Watcher Debug Raw command sent (Node 19): 01 1E 00 13 13 17 98 C1 BB 04 FC 0D FC 22 FA 3E B0 5C A9 B7 69 24 4F 95 F8 7A 00 9B 5C 25 8E 70 (True)
Z-Wave sent "Garasjeport" open
Z-Wave Watcher Debug Raw command sent (Node 19): 01 11 00 13 13 0A 98 80 AB 3B 4C 07 DF 1A F4 2E 25 8F 92 (True)
Z-Wave Watcher Debug Raw command received (Node 19): 01 08 00 04 00 13 02 98 40 3A
Z-Wave received "Garasjeport" status update is opening
Z-Wave Watcher Debug Raw command received (Node 19): 01 09 00 04 00 13 03 66 03 FE FF
Z-Wave Watcher Debug Raw command received (Node 19): 01 1D 00 04 00 13 17 98 81 1D 59 73 63 45 00 9E 2E 7C B4 BE F1 AB 00 49 3D 5B 01 AF 9B 6A 06
Z-Wave Watcher Debug Raw command sent (Node 19): 01 11 00 13 13 0A 98 80 F3 FC 39 CF 5C 22 E0 C6 25 90 E8 (True)
Z-Wave Watcher Debug Raw command received (Node 19): 01 09 00 04 00 13 03 66 03 FF FF
Z-Wave Watcher Debug Raw command received (Node 19): 01 1D 00 04 00 13 17 98 81 4B 44 73 AC 1F 68 19 0C BD 44 1B 74 F3 2A B0 CB E8 D7 B2 B8 35 7D
Z-Wave Watcher Debug Raw command sent (Node 19): 01 09 00 13 13 02 98 40 25 91 98 (True)
Z-Wave Watcher Debug Raw command sent (Node 19): 01 1E 00 13 13 17 98 C1 E5 17 9F 16 AD 4A D2 DD 1D FB 5F B9 60 2A 45 2D 7D 2A C5 74 75 25 92 3A (True)
Z-Wave sent "Garasjeport" close
Z-Wave Watcher Debug Raw command sent (Node 19): 01 11 00 13 13 0A 98 80 30 0C AF 23 89 6F C8 5C 25 93 88 (True)
Z-Wave received "Garasjeport" status update is closing
Z-Wave Watcher Debug Raw command received (Node 19): 01 09 00 04 00 13 03 66 03 FC FF
Z-Wave Watcher Debug Raw command received (Node 19): 01 1D 00 04 00 13 17 98 81 1A AB 04 90 A2 70 8E 1C DC 25 EC 88 30 BD AD 3E AB 55 0E DC 0E 3F
Z-Wave Watcher Debug Raw command sent (Node 19): 01 11 00 13 13 0A 98 80 5D 16 63 1C 1D 23 16 D9 25 94 88 (True)
Z-Wave received "Garasjeport" status update is closed
Z-Wave Watcher Debug Raw command received (Node 19): 01 09 00 04 00 13 03 66 03 00 FF
Z-Wave Watcher Debug Raw command received (Node 19): 01 1D 00 04 00 13 17 98 81 40 15 32 0C CB F8 EC C2 EE A9 4B 63 5D 37 94 18 AD 55 E5 0E 8B 9C
Pressing the second button on Fibaro dimmer 2, nothing happens with the garage door. It is both associated to group 4 and there is a trigger which sends the raw command.
- Code: Select all
Z-Wave Watcher Debug Raw command sent (Node 21): 01 11 00 13 15 0A 98 80 BD 6A 6B 43 13 8A C8 C4 25 95 20 (True)
Z-Wave Watcher Debug Raw command received (Node 21): 01 08 00 04 00 15 02 98 40 3C
Z-Wave received "Yttergang" scene 26
Trigger Veggknapp yttergang garasjeport
Z-Wave Watcher Debug Raw command received (Node 21): 01 0A 00 04 00 15 04 2B 01 1A 00 FF
Z-Wave Watcher Debug Raw command received (Node 21): 01 1E 00 04 00 15 18 98 81 4A F0 B2 58 19 AD 7F 44 B2 51 65 AB 41 BD 63 7D F4 55 E1 64 6D B2 1A
Z-Wave sent "Garasjeport" raw command [20 01 FF]
Z-Wave Watcher Debug Raw command sent (Node 19): 01 0A 00 13 13 03 20 01 FF 25 96 9B (True)
I've tried to set parameter 25 to 0 and 16 for the Fibaro, parameter 27 is set to 15.
Manual for the Fibaro:
https://manuals.fibaro.com/content/manu ... T-v1.1.pdfI'm all out of ideas, so appreciate any tips on how to get this working.
Edit: Firmware version of the Aeotec garage door controller is 1.14, latest I can find reference to on Aeotecs web site is 1.12.
