matt (support) wrote:We did add a device definition for the ZW062, but I was unable to get it working correctly. It might have been that my particular module had old/beta firmware though. I'm still waiting for details on Aeotec on how I can update it. So please let us know if it works for you.
Hi Matt,
I added the controller and it's working.
Its got Turn On/Off command and in the device settings:
- Screen Shot 2016-11-15 at 17.32.20.png (43.39 KiB) Viewed 3702 times
Still have to hook it up to test. Below is the sync log:
Z-Wave started controller inclusion mode with encryption
Z-Wave controller included module: 051 - Secure Barrier Add-On
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "051 - Secure Barrier Add-On"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 8, 16, 23, 25, 26, 27, 28, 31, 32, 34, 37, 38, 39, 40, 45
Z-Wave Syncing - assigning return route to "051 - Secure Barrier Add-On"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Garage Door Controller (ZW062) - 0203003E
Schedule Time Update
Z-Wave Syncing - retrieved protocol version 3.99, app version 1.11
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Secure Barrier Add-On (04 : 40 : 07, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 82v1 25v1 86v1 70v1 71v1 72v1 73v1 5Av1 98v1 59v1 7Av1 66v1 5Ev1 85v1
Z-Wave Syncing - retrieved encrypt commands: 82 25 86 70 71 72 73 59 5A 66 7A 85
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Syncing - retrieved parameter 35 "Sensor calibration timeout" is 30 seconds
Z-Wave Syncing - retrieved parameter 37 "Alarm mode when opening" is 167905281
Z-Wave Syncing - retrieved parameter 38 "Alarm mode when closing" is 134416385
Z-Wave Syncing - retrieved parameter 39 "Alarm mode when unknown" is 100927488
Z-Wave Syncing - retrieved parameter 40 "Alarm mode when closed" is 33883392
Z-Wave Syncing - retrieved parameter 80 "State change report type" is 2
Z-Wave Syncing - changed device "050 - Door Controller" address from undefined to 051
Z-Wave Syncing - complete
The module did add on my previous version, which in my case was also a beta I presume which was v1.03 or some such. I managed to update it to v1.11 using the instructions provided here by Aeotec:
https://aeotec.freshdesk.com/support/so ... ware-v1-11You obviously need a windows machine and just a tip, make sure you have installed the drivers for the z stick otherwise it'll start the update and fail. Took me all of the afternoon to figure that one out and didn't realise since windows said it installed the drivers automatically which obviously it did not!!
P.S. Thanks durosity for the push to try it!!
