- Posted on
Sat Nov 27, 2021 11:12 am
racarter
offline
Hi Matt
Yes, FGBS-222
Here's the log:
Z-Wave Syncing - started for "Doorbell In"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 6, 7, 11, 12, 13, 15, 17, 18, 19, 20, 22, 26, 27, 28, 29, 30, 55, 59, 60, 61
Z-Wave Syncing - assigning return route to "047 - Doorbell In"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smart Implant (FGBS222) - 05021000
Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Syncing - retrieved parameter 20 "Input 1 type" is 1 "Normally Open"
Z-Wave Syncing - retrieved parameter 40 "Input 1 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 21 "Input 2 type" is 1 "Normally Open"
Z-Wave Syncing - retrieved parameter 41 "Input 2 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 24 "Swap inputs (IN1 and IN2)" is false
Z-Wave Syncing - retrieved parameter 154 "Output 1 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 156 "Output 1 delayed off" is 2 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 155 "Output 2 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 157 "Output 2 delayed off" is 0 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 25 "Swap outputs (OUT1 and OUT2)" is false
Z-Wave Syncing - retrieved parameter 66 "Internal temperature interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 65 "Internal temperature sensitivity" is 5 * 0.1°C
Z-Wave Syncing - device "047 - Doorbell In" parameter 65 "Internal temperature sensitivity" changed to 255 * 0.1°C (was 5 * 0.1°C)
Z-Wave Syncing - retrieved parameter 64 "Analog input interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 63 "Analog input sensitivity" is 0 * 0.1 V
Z-Wave Syncing - retrieved parameter 150 "Analog IN1 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 151 "Analog IN2 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 68 "External sensor interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 67 "External sensor sensitivity" is 5 * 0.1
Z-Wave Syncing - device "047 - Doorbell In" parameter 67 "External sensor sensitivity" changed to 0 * 0.1 (was 5 * 0.1)
Z-Wave Syncing - complete
Z-Wave sent "Doorbell In" status request
Z-Wave sent "Doorbell Spare AI 1" status request
Z-Wave received "Doorbell Spare AI 1" sensor update to 10.29 V
Z-Wave sent "Doorbell Spare DI 2" status request
Z-Wave sent "Doorbell Spare AI 2" status request
Z-Wave sent "Doorbell Out" status request
Z-Wave sent "Doorbell Spare DO 2" status request
Z-Wave sent "Doorbell Temperature" status request
Z-Wave received "Doorbell Temperature" sensor update to 32.7 °C
