- Posted on
Sun Nov 12, 2023 2:27 pm
wjlevin
offline
Thanks for your reply, Matt.
None of my Z-Wave devices are working. I did have a switch working as well as 2 motion/temperature sensors at one time.
Here is the log from the reload.
Nov 12, 2023 at 3:23:41 PM
Reloading interface "Z-Wave 2023.1.0" using API v3.3
Stopping interface "Z-Wave 2023.1.0" (pid 4370)
Z-Wave Debug stop_concurrent_thread called
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave closed connection to Z-Stick Gen5+ (ZW090)
Stopped interface "Z-Wave 2023.1.0"
Starting interface "Z-Wave 2023.1.0" (pid 51240)
Started interface "Z-Wave 2023.1.0"
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 36 2E 30 37 00 01 97 (no inbound callback)
Z-Wave Debug . . getVersion: Z-Wave 6.07 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 E3 51 EE 58 01 D3 (no inbound callback)
Z-Wave Debug . . getHomeID: E351EE58, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 38 C7 (no inbound callback)
Z-Wave Debug . . getInterfaceFeatures: 38
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 02 00 86 00 01 00 5A FE 87 7F 88 CF 7F C0 4F FB DF FD E0 67 00 80 80 00 80 86 00 01 00 E8 73 00 80 0F 00 00 60 00 00 90 (no inbound callback)
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 0A 0B 10 11 12 13 14 15 16 17 1C 20 21 22 23 24 27 28 29 2A 2B 2C 2D 2E 2F 37 38 39 3A 3B 3C 3F 41 42 44 45 46 47 48 49 4A 4B 4C 4D 4F 50 51 53 54 55 56 57 58 5E 5F 60 61 62 63 66 67 78 80 90 92 93 98 A1 B4 B6 B7 B8 B9 BA BD BE BF D0 D1 D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.02, manufactureId 0086, productType 0001, productId 005A
Z-Wave Debug . . getInterfaceApiCapabilities: SDK6.60.00+ (expecting RSSI value and securityKeyType bytes)
Z-Wave Debug . . getInterfaceApiCapabilities: supportsGetClearNetworkStats
Z-Wave Debug . . getInterfaceApiCapabilities: supportsTransmissionMetrics
Z-Wave Debug SENT setApiSetup: 01 05 00 0B 02 01 F2
Z-Wave Debug RCVD setApiSetup: 01 05 01 0B 02 01 F3 (no inbound callback)
Z-Wave Debug . . setApiSetup: transmissionMetrics enabled
Z-Wave Debug . . getInterfaceApiCapabilities: supportsBackupRestore
Z-Wave Debug . . getInterfaceApiCapabilities: supportsS2
Z-Wave Debug . . getInterfaceApiCapabilities: supportsSmartStart
Z-Wave connected to Z-Stick Gen5+ (ZW090) interface on /dev/cu.usbmodem13401 (firmware 1.02, minimum SDK 6.81.06)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 08 08 1D 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 C0 (no inbound callback)
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 16 01 02 02 01 73 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
I'm not at home now - I did the above remotely. Still, I started the New Device prodcedure and I'm still not getting anything in the drop down "Sync using node:" . Please see attached.
- Screenshot 2023-11-12 at 3.26.15 PM.png (392.1 KiB) Viewed 1087 times
