It works in Indigo...but it's annoying me...the log fills with every single energy update. I changed the Polling to once every hour, but it still seems to send an update to Indigo any time the power consumption changes...
Here's the device info:
- Code: Select all
Indigo Z-Wave Version: 2.0.96
Node ID: 77
Model: Relay Power Switch
Model ID: 0101000A
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 4.34
Application Version: 1.02
Model Definition Version: 0
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 27v1 2Bv1 2Cv1 32v3 70v1 72v1 73v1 59v1 7Av1 5Av1 5Ev1 85v1
Features: routing, beaming, energyMeter
Neighbors: - none -
Associations: 1:[1]
Config Values: - none -
And here's a sample of the log getting hammered by this device:
- Code: Select all
Z-Wave received "Front Porch - Sensor - Temperature" sensor update to 66.2 °F
Z-Wave received "Front Porch - Sensor - Humidity" sensor update to 53%
Z-Wave received "Living Room Entertainment Center" power load to 41.912 W
Z-Wave received "Front Porch - Sensor - Luminance" sensor update to 0 lux
Z-Wave received "Front Porch - Sensor - Ultraviolet" sensor update to 0
Z-Wave received "Living Room Entertainment Center" power load to 54.022 W
Z-Wave received "Living Room Entertainment Center" power load to 48.335 W
Z-Wave received "Living Room Entertainment Center" power load to 41.993 W
Z-Wave received "Living Room Entertainment Center" power load to 47.669 W
Z-Wave received "Living Room Entertainment Center" power load to 41.832 W
Z-Wave received "Living Room Entertainment Center" power load to 46.975 W
Z-Wave received "Living Room Entertainment Center" power load to 42.074 W
Z-Wave received "Living Room Entertainment Center" power load to 57.146 W
Z-Wave received "Living Room Entertainment Center" power load to 47.021 W
Z-Wave received "Living Room Entertainment Center" power load to 41.872 W
Z-Wave received "Living Room Entertainment Center" power load to 47.716 W
Z-Wave received "Living Room Entertainment Center" power load to 41.792 W
Z-Wave received "Living Room Entertainment Center" power load to 47.067 W
Z-Wave received "Living Room Entertainment Center" power load to 40.639 W
Z-Wave received "Front Porch - Sensor - Temperature" sensor update to 66.3 °F
Z-Wave received "Living Room Entertainment Center" power load to 47.204 W
Z-Wave received "Living Room Entertainment Center" energy total to 0.126 kWh
Z-Wave received "Living Room Entertainment Center" power load to 48.383 W
Z-Wave received "Living Room Entertainment Center" power load to 42.443 W
Z-Wave received "Living Room Entertainment Center" power load to 54.820 W
Z-Wave received "Living Room Entertainment Center" power load to 47.952 W
Z-Wave received "Living Room Entertainment Center" power load to 41.952 W
Z-Wave received "Living Room Entertainment Center" power load to 48.047 W
Z-Wave received "Living Room Entertainment Center" power load to 57.887 W
Z-Wave received "Living Room Entertainment Center" power load to 44.326 W
Any way to cut down on the messages or anything? Matt? Jay?
Ross
