I tried setting the overload alarm to 10W for one of the dimmers, turning it on and it will turn off immediately, debug log:
- Code: Select all
Z-Wave sent "Gang Bad" on
Z-Wave Debug queueing energy request of "020 - Gang Bad" (activity detected)
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 14 03 26 03 0F CF
Z-Wave Debug . . requestDimmerStatus: node 020, endpoint None, value 15
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 00 5B AC
Z-Wave Debug . . requestVarSensorStatus: node 020, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 9.1 W (float: 9.100000)
Z-Wave Debug received "Gang Bad" power load to 9.1 W
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 01 1E E8
Z-Wave Debug . . requestVarSensorStatus: node 020, endpoint None, type 4, raw value 2201...
Z-Wave Debug . . requestVarSensorStatus: 28.6 W (float: 28.600000)
Z-Wave Debug received "Gang Bad" power load to 28.6 W
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 14 03 26 03 00 C0
Z-Wave Debug . . requestDimmerStatus: node 020, endpoint None, value 0
Z-Wave received "Gang Bad" status update is off
Z-Wave Debug ignoring duplicate energy request of "020 - Gang Bad" (activity detected)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 14 09 71 05 00 00 00 FF 08 08 00 62
Z-Wave Debug . . requestAlarmSensorStatus: node 020, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 8, valueExt 8, classSubKeyExt 7100000808
Z-Wave Debug polling status of node "020 - Gang Bad" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 14 03 32 01 00 25 67 80
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 14 0A 32 02 21 44 00 00 00 D2 00 00 72
Z-Wave Debug . . requestMeterLevel: node 020, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 2.10 kWh (float: 2.100000)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 14 03 32 01 10 25 68 9F
Z-Wave Debug RCVD requestMeterLevel: 01 0E 00 04 00 14 08 32 02 21 32 01 1E 00 00 D5
Z-Wave Debug . . requestMeterLevel: node 020, endpoint None, meterType 01, raw value 3201...
Z-Wave Debug . . requestMeterLevel: 28.6 W (float: 28.600000)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 14 06 31 05 04 22 00 00 F7
Z-Wave Debug . . requestVarSensorStatus: 0.0 W (float: 0.000000)
Z-Wave Debug received "Gang Bad" power load to 0.0 W
