Travis,
Does this plugin work with the TL-150?
Chris
Oct 29, 2011 9:30:45 PM
DSC Alarm Error Checksum did not match on a received packet.
tnvol wrote:Travis never responded and I've been unable to get the TL-150 to work.
jay wrote:That might be an easy fix - we added a new Serial Port field type that will allow the user to select either a physical serial port or specify a serial-over-ip URL. It doesn't require a lot of code change to use it either.
@travisc - how about it?
travisc wrote:@mrcandy
What is the verification error when you try to save the config settings? If the settings can't save then the plugin definitely won't work.
The config screen used to always pop up when the plugin was first started, but that seemed to change after one of the betas. Now it seems you have to open it yourself.
Are you selecting a valid serial port? If you are, turn on Debug and PM me the relevant log lines.
Travis
mrcandy wrote:Hi Travis
Thanks for getting back to me. Unfortunately I've only ever managed to get to the config popup twice and didn't get info from the log either time. I don't think I can accurately find those locations in the log now.
When Indigo starts, or I reload the plugin, I never get the popup automatically. I get one of the comm error messages shown in red in my original post in both cases. If I try to use the menu to get the config popup, I get the spinning beachball until another of the comm error messages gets posted. I do have a serial interface connected via a keyspan USB converter, but I am unable to get to the config screen to set it up.
BTW I upgraded indigo to 5.0.0 release (no beta) and it hasn't made a difference. I've tried removing and re-installing both Indigo and the plugin with no change.
2011-11-18 7:44:13 PM
Enabling plugin "DSC Alarm 0.9.3"
Starting plugin "DSC Alarm 0.9.3"
Plugin "DSC Alarm" connected
DSC Alarm Debug plugin init
DSC Alarm Debug pluginId: com.frightideas.indigoplugin.dscAlarm
DSC Alarm Debug pluginDisplayName: DSC Alarm
DSC Alarm Debug pluginVersion: 0.9.3
DSC Alarm Debug creating DSC object
DSC Alarm Debug DSC init started
DSC Alarm Debug DSC init complete
DSC Alarm Debug DSC create done
Plugin "DSC Alarm 0.9.3" started
Error (client) getXmlFromPlugin() caught exception: ServerCommunicationError -- timeout waiting for plugin response
DSC Alarm Debug plugin startup called
DSC Alarm Debug DSC startup called
mrcandy wrote:Travis
No change when I delete the prefs file, although note that the prefs file does not seem to get re-created on the next start of the plugin (although I haven't made it to the config screen successfully yet tonight).
# Concurrent Thread Start / Stop
def startComm(self):
self.plugin.debugLog(u"startComm called")
oldTime = time.time()
# While Indigo hasn't told us to shutdown
while self.shutdown == False:
# Read indigo pluginPrefs into our own variables
# Keep trying to read until it works. On the very first startup of the plugin the
# pluginPrefs Dict is not valid right away, we must poll till it is.
if self.configRead == False:
self.plugin.sleep(1)
if self.getConfiguration(self.plugin.pluginPrefs) == True:
