v2022.0.1 zone status broken ?
Thu Jul 14, 2022 10:34 am
Monstergerm offline
Re: v2022.0.1 zone status broken ?
I have to review log in more detail.
But what exactly do you mean with UI does not update?
And here are two links for spring hinges. We have them on all doors that I don't want to stay open and they blend right in with the regular hinges.
https://deltana.net/catalog/steel-stainless-steel-and-spring-hinges/viewing/spring-hinge-single-action-steel/131_4x-4-spring-hinge-ul-listed
https://emtek.com/door-hinges/sh-4-14r-hinge
Fri Jul 15, 2022 7:46 pm
new2me07 offline
Sorry for the confusion, when I say UI I'm referring to the indigo server application window, as I was watching the device states there. I have a motion with an LED indicator, and under normal circumstances it reports immediately, LED on = motion, LED off = no motion. All my zones freeze a couple of seconds after the disarm event, according to the device list (maybe quit updating in real time). I will dig deeper at an appropriate hours for the sirens to go off, and see if said zones will still trigger other automations.
But I guess the point is moot bc I just ordered 3 sets of the some similar hinges, I had no idea that type was in the residential market.
Sat Jul 16, 2022 10:30 am
Monstergerm offline
I figured out what is going on. The UI is not frozen but as you noticed the zone states are frozen. This is a feature of the plugin to preserve open zone states during an alarm event. The problem I noticed is when one disarms a keypad induced panic alarm (also applies to keypad fire alarms) the DSC panel does not respond with a disarm acknowledgment. This causes a few problems, like in your case the plugin thinks the alarm is still going on.
I think I figured out a work around. Can you try this version and let me know if it works in your case. I willl then incorporate those changes in the next official release.
https://www.dropbox.com/s/02mn8rbhid44mk6/DSC%20Alarm.indigoPlugin.zip?dl=0
Sun Jul 24, 2022 11:04 am
new2me07 offline
Works wonderfully, thank you!
Might have to start hitting the fam with the siren when the bonus son starts "raging" on xbox. Time to start digging into pulling audio streams and analyzing volume and profanity. Need one at office now that I think about it :D
