DSC error
Mon Jan 24, 2022 9:00 am
berkinet offline
DSC error
I have started constantly seeing the following error from the DSC plugin:
 IT-100/Envisalink Error (011): Keybus Transmit Time Timeout
At first I thought it was the EnvisaLink and was prepared to just replace it. However, I am now thinking this is a problem with the panel. Does anyone have any thoughts or advice?
Mon Jan 31, 2022 11:28 am
Re: DSC error
Are you having any issues with your keypads at all? If not could just be a wiring fault with the envisalink. If memory serves there's a way to monitor the keypads and show it in alarm memory if it faults, so if it doesn't come up on a keypad I'd suspect the envisalink/wiring.
Mon Jan 31, 2022 11:31 am
berkinet offline
Re: DSC error
No, no keypadproblen=ms and, other than the error messages from the plugin, the alarm seems to function properly. At least it follows zone changes.
Mon Jan 31, 2022 12:38 pm
Re: DSC error
Tried restarting the system?
Mon Jan 31, 2022 12:51 pm
berkinet offline
Re: DSC error
Yup. Pulled the battery, pulled the fuse, had a cupa coffee....
Mon Jan 31, 2022 1:18 pm
Re: DSC error
exorsism?
I'd bet it's the envisalink but the only way to be sure would be to swap it out. Its a lot easier to replace that than it is to replace the whole panel.
Wed Feb 02, 2022 7:45 pm
Monstergerm offline
Re: DSC error
I am wondering if this has anything to do with transmitting the Time. Is your Envisalink monitored by EyezOn? Sometimes they get slightly different error messages. So to doublecheck, is the time of the panel correct and in sync with the Indigo Server time? Is everything else working fine with the Envisalink?
The Keybus communicates with the keypads and the Envisalink. If all keypads are working fine it could the the Envisalink. Is it on latest firmware? Did you go to the internal website of the Envisalink to check for any errors? Did you try to reboot Envisalink from its internal website? There is also a way to factory reset it.
Thu Feb 03, 2022 7:41 am
berkinet offline
Re: DSC error
Monstergerm wrote:
I am wondering if this has anything to do with transmitting the Time. Is your Envisalink monitored by EyezOn? Sometimes they get slightly different error messages. So to doublecheck, is the time of the panel correct and in sync with the Indigo Server time? Is everything else working fine with the Envisalink?....
That was it. Yes, the alarm time had drifted and I had just ignored it since we only use the system for home automation purposes. Time reset, error messages disappeared. Thanks!
Thu Feb 03, 2022 3:28 pm
Monstergerm offline
Re: DSC error
I am glad you got it to work. Out of curiosity, how much was the time difference between the panel and the Indigo Server?
Thu Feb 03, 2022 4:16 pm
berkinet offline
Re: DSC error
2 days more or less
