DSC Plugin Error
Mon Sep 14, 2020 4:44 pm
omar offline
DSC Plugin Error
I am running Indio 7.4 and have installed the plugin V2.2.2 im getting this error :
DSC Alarm Debug startup called
DSC Alarm Debug getConfiguration start
DSC Alarm Debug Configuration read successfully
DSC Alarm Debug <<-- entering deviceStartComm: Dinning Room (1456760044 - alarmZone)
DSC Alarm Debug exiting deviceStartComm -->>
DSC Alarm Debug <<-- entering deviceStartComm: DSC (67492404 - alarmKeypad)
DSC Alarm Debug Adding keypad: {1: 67492404}
DSC Alarm Debug <<-- entering deviceStartComm: Entrance (869959073 - alarmZone)
DSC Alarm Debug <<-- entering deviceStartComm: Fireplace (1081825026 - alarmZone)
DSC Alarm Debug <<-- entering deviceStartComm: Hall Garage (1333638940 - alarmZone)
DSC Alarm Debug <<-- entering deviceStartComm: Kitchen (658330314 - alarmZone)
DSC Alarm Debug <<-- entering deviceStartComm: Salon (352637388 - alarmZone)
DSC Alarm Debug runConcurrentThread called
DSC Alarm Debug STATE: Startup
DSC Alarm Initializing communication on port /dev/cu.wchusbserial1470
DSC Alarm Communication established
DSC Alarm Enabling Time Broadcast
DSC Alarm Debug TX: 0561CC
DSC Alarm Error Timed out after waiting for response to command 0561 for 3 seconds, retrying.
DSC Alarm Error Resent command 0561 3 times with no success, aborting.
DSC Alarm Error Error enabling Time Broadcast.
DSC Alarm Plugin will attempt to re-initialize again in 3 minutes.
i tried different usb to serial adapters no luck .
Any help is appreciated.
Omar
Mon Sep 14, 2020 5:27 pm
Monstergerm offline
Re: DSC Plugin Error
Hmm, not sure what is going on there. As your error message states your security panel does not respond to an "enable time broadcast" request by the plugin. This is part of the startup sequence and seems to interrupt the rest of the sequence when there is a failure.
What device are you using?
Did you ever get this to work before or is this a new install?
Mon Sep 14, 2020 9:18 pm
omar offline
Hi , im using iT100 connected to usb 2 serial adapter , im using the plugin for the first time .
DSC Alarm Debug validating Prefs called
DSC Alarm Error IT-100/Envisalink Error: Received a response with invalid characters
Mon Sep 14, 2020 10:47 pm
Monstergerm offline
I can’t troubleshoot this here sine I have an EVL-4 with IP connection.
But we can try a few things. Are you familiar enough with Indigo plugins to make some changes to the code?
Tue Sep 15, 2020 3:12 am
omar offline
yes i can try mod the code
Tue Sep 15, 2020 8:37 am
A couple of things:
  1. What USB cable and driver are you using? I don't recognize the driver-assigned port name. USB to serial drivers on macOS can sometimes be pretty finicky...
  2. Have you tried completely restarting your panel? I've had multiple occasions where my IT-100 board got into an unknown state and the only way to recover was to unplug both from the wall and the battery backup and force a full restart of the panel.
Tue Sep 15, 2020 9:52 am
Monstergerm offline
Let's try two things with the code. The time broadcast is not that useful since it happens only every 4 minutes and by default is off anyway.
1) Disable time broadcast:
change code line 2170 to
            rx = self.sendPacket('0560')
Then save plugin and reload.
2) Skip time broadcast:
if disabling does not work, skip the whole time broadcast routine.
change code line 2163 to
               self.state = self.States.BOTH_PING
But as Jay said, if there is something wonky with the state of the IT-100 or the cable/driver then this might not work.
Tue Sep 15, 2020 2:11 pm
If if was any use to you I have a spare IT-100 I'd be happy to send to you if you covered the postage?
Wed Sep 16, 2020 4:27 pm
omar offline
jay (support) wrote:
A couple of things:
hi jay , im using Chinese usb serial cable , with this driver https://github.com/adrianmihalko/ch340g ... s-x-driver , i believe it's probably the cable , i will buy new one and test , thanks for the hint .
Wed Sep 16, 2020 4:34 pm
omar offline
hi , i did both modifications of the code but didn't work , as mentioned by jay and you , it could be the cable or the driver , i had same headache in the past with serial connection on OS X , thanks for all , will buy new cable and test or i will get envisalink interface .
Wed Sep 16, 2020 4:45 pm
Monstergerm offline
I recommend EVL-4; it has a lot more features than the IT-100.
FYI, on the same Mac running Indigo under Mojave I am controlling a different serial device with the PL-2303 USB-to-Serial Cable Adapter with the latest PL-2303 Mac driver. I never had any problems with this.
Wed Sep 16, 2020 4:50 pm
If it were me, I'd get an FTDI-based cable since the driver is included with macOS.
Thu Sep 17, 2020 2:58 am
omar offline
i ordered EVL-4 , network connection is better and easy to setup , thanks for your precious help .
Thu Sep 17, 2020 3:04 am
omar offline
true FTDI based devices work out of box , i ordered EVL-4,:D :D :D , thanks Jay.
Fri Sep 18, 2020 12:36 pm
Just FYI I have both a EVL4 and an IT-100, I find the IT100 better for use if you’re using the motion sensors for triggering actions for things like lights coming on.. the latency is substantially better, the EVL has a short delay that kinda is annoying.
