DSC Plugin and EVL-3 interface not working.
Posted: Sat Aug 27, 2016 2:43 am
I have an ADT Safewatch 3000 Pro (same as Vista 20P - I think) and I purchased an EYEZ-ON EVL-3 Envisalink Internet Alert Module for DSC & Honeywell Security units. I can login to the EVL-3 web interface and see zone statuses and all, but I cannot get the DSC Alarm plugin to get Ingido talking with it.
I truly don't know much about the alarm panel or the EVL-3, but I'd like to figure it out one day and be able to use any of the alarm sensors to trigger Indigo to respond (lights, siren (eventually), camera recording (SecSpy) and text messaging me.
Here's all the most recent error messages from the log from where I updated and enabled the plugin.
Here's the proof that the EVL-3 is talking to the panel:
Any ideas what I am doing wrong? I'm a total noob with this panel and such so I'm struggling a lot. I've considered buying the alphanumeric keypad to swap out for my primary pad so I can better work with it.
If anyone here knows these panels well, please help a fellow geek out.
Ross
- Code: Select all
Upgrading plugin DSC Alarm to newer version 2.0.6 (previous version moved to trash)
Loading plugin "DSC Alarm 2.0.6"
Starting plugin "DSC Alarm 2.0.6" (pid 44858)
DSC Alarm Log level preferences are set to "Normal".
SQL Logger creating table variable_history_254644808 for "DSCalarmText"
SQL Logger creating table variable_history_81110068 for "DSCalarmMemory"
SQL Logger creating table variable_history_1540956115 for "DSCcommand"
Started plugin "DSC Alarm 2.0.6"
DSC Alarm Your plugin version, v2.0.6, is current.
DSC Alarm Initializing communication at address: 192.168.100.99:4025
DSC Alarm Error IT-100/Envisalink Error: Received a response with invalid characters
DSC Alarm Error Checksum did not match on a received packet.
DSC Alarm Error Timed out after waiting for response to command 005HD5dK3 for 3 seconds, retrying.
DSC Alarm Error Resent command 005HD5dK3 3 times with no success, aborting.
DSC Alarm Error Timeout waiting for Envisalink to respond to login request.
DSC Alarm Plugin will attempt to re-initialize again in 3 minutes.
Aug 27, 2016, 3:14:54 AM
DSC Alarm Log level preferences changed to "Intense Debug".
DSC Alarm Debug getConfiguration start
DSC Alarm Debug Configuration read successfully
DSC Alarm Debug RX: Login:
DSC Alarm Debug TX: 005HD5dK338
DSC Alarm Debug RX: FAILED
Ross
