[SOLVED]: Error after upgrading to 6.1.9
Mon May 16, 2016 8:04 am
caseyz offline
After upgrading to 6.1.9 I get the following error in the event log most times an event is returned from the alarm.
DSC Alarm Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1521, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DSC Alarm 11.25.15 AM.indigoPlugin/Contents/Server Plugin/indigoPluginUpdateChecker.py", line 109, in checkVersionPoll
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DSC Alarm 11.25.15 AM.indigoPlugin/Contents/Server Plugin/indigoPluginUpdateChecker.py", line 114, in checkVersionNow
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 313, in debugLog
AttributeError: 'logger' object has no attribute 'debug'
DSC Alarm Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mon May 16, 2016 8:06 am
Re: Error after upgrading to 6.1.9
See this forum thread and download the modified version of the plugin I posted there.
