[ANSWERED] Error in Plugin update check
Fri Mar 11, 2016 6:30 am
Radjin offline
Has anyone seen this error? I woke up to it this morning and restarting the Indigo server, disabling and reenabling the plugin has not worked.
DSC Alarm Error_______________Error in plugin execution runConcurrentThread:
File "plugin.py", line 107, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DSC Alarm.indigoPlugin/Contents/Server Plugin/indigoPluginUpdateChecker.py", line 109, in checkVersionPoll
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DSC Alarm.indigoPlugin/Contents/Server Plugin/indigoPluginUpdateChecker.py", line 114, in checkVersionNow
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 190, in debugLog
<type 'exceptions.AttributeError'>: 'logger' object has no attribute 'debug'
It's not rocket science...
Fri Mar 11, 2016 6:43 am
Re: Error in Plugin update check
Radjin wrote:
Has anyone seen this error? I woke up to it this morning and restarting the Indigo server, disabling and reenabling the plugin has not worked. ....
Apparently so :wink: - take a look at the previous post in this forum: error in log after install of latest Indigo update 6.1.7 - I think this may be the same or similar error? :)
Fri Mar 11, 2016 6:44 am
jens offline
Yes, Matt have Done à fix, posted under Dsc
Sent from my iPhone 6 using Tapatalk
