Boolean On/Off state for PIR and Door Contacts
Sun Oct 05, 2014 9:06 am
AndyVirus offline
Hello,
Would it be possible to add boolean on/off states for the DSC PIR's and Door Contacts within the DSC plugin? The reason for this is so I can use these PIR's in the inbuilt group trigger plugin. I have been meaning to ask for a while but it was not urgent until now as my Triggers are in the tens's to hundreds as i need to have an action per trigger. I would be able to reduce the number of triggers i have by about 4x if i could have 1 Trigger for multiple PIR's.
I asked about this a while back on the Group Trigger group and this was the answer: http://forums.indigodomo.com/viewtopic.php?f=84&t=11758 hence asking here.
Mon Oct 06, 2014 3:31 pm
Re: Boolean On/Off state for PIR and Door Contacts
Are you into programming at all?
Travis put the plugin up on GitHub last month in case anyone wanted to pull/fork it.
Sat Oct 11, 2014 8:54 am
AndyVirus offline
Noo... I am useless when it comes to coding. Just an end user. :(
Maybe if someone with skills is making a modification next they could lump this in also so that DSC devices work like other PIRs such as Z-Wave and LightwaveRF, so they can be used in Virtual Device Groups. Ill use a variable for now to define motion zones (more than 1 PIR per room/action).
