Error with Envisalink 3 and Vista 20p
Wed May 14, 2014 7:34 pm
dtm offline
I am getting this error when I turn on the DSC Alarm Plugin.
I have the Debug level set to Intense and this is what the log reports.
Here are the system specs: OS X 10.9.2, Indigo 6.0.11, Envisalink-3 Firmware Version: 01.11.128A, DSC Alarm Plugin 1.5.4, Vista 20p
May 14, 2014, 9:25:03 PM
DSC Alarm Debug validating Prefs called
DSC Alarm Debug STATE: Startup
DSC Alarm Log level preferences changed to "Intense Debug".
DSC Alarm Debug getConfiguration start
DSC Alarm Debug Configuration read successfully
DSC Alarm Initializing communication at address: 192.168.1.20:4025
DSC Alarm Debug RX: Login:
DSC Alarm Error IT-100/Envisalink Error: Received a response with invalid characters
DSC Alarm Debug TX: 005user54
DSC Alarm Debug RX: FAILED
DSC Alarm Error Checksum did not match on a received packet.
DSC Alarm Error Timed out after waiting for response to command 005user for 3 seconds, retrying.
DSC Alarm Error Resent command 005user 3 times with no success, aborting.
DSC Alarm Error Timeout waiting for Envisalink to respond to login request.
DSC Alarm Plugin will attempt to re-initialize again in 3 minutes.
Any assistance you can give would be greatly appreciated.
Wed Jul 09, 2014 5:17 pm
dtm offline
Re: Error with Envisalink 3 and Vista 20p
I guess Travis isn't working on this plugin anymore?
Wed Jul 09, 2014 6:20 pm
I suspect he's just busy - he's usually pretty good at getting back to people. He might have just missed this post.
Wed Jul 09, 2014 7:34 pm
berkinet offline
The plugin supports the DSC message format. Although both DSC and Vista use the same electrical signaling, the plugin is likely not compatible with the Vista Message format, which is quite different.
Fri Dec 03, 2021 10:57 pm
classicmac offline
Has anyone been successful integrating a Envisalink 3 with Vista 20p?
Sat Dec 04, 2021 12:24 pm
Monstergerm offline
The Envisalink should work just fine with the Vista panel. But of course the DSC plugin will not work since it only supports DSC panels.
Mon Jan 24, 2022 4:55 am
berkinet offline
Will this plug-in work with the EnvisaLink 4?
Mon Jan 24, 2022 6:35 am
Yep I use an envisalink 4 connected to a DSC system with the plugin.
Mon Jan 24, 2022 7:29 am
berkinet offline
Thanks.
