Every time the Plugin reloads - all smartphones are "home"
Wed Feb 10, 2021 7:54 pm
EagleDTW offline
Hi Travis,
Love this plugin. Every time the Plugin reloads - all smartphones are seen as at "home". I'm wondering if there is a way to change this feature, or if I could grab the pid of the running instance and compare and set a timer for after xx number of minutes to have it actuate triggers instead of immediately after a reload and no presence truly detected.
Any thoughts on how this could be easily accomplished?
Thank you,
Daniel
Thu Feb 11, 2021 6:06 pm
Re: Every time the Plugin reloads - all smartphones are "hom
You can try the Fingscan plugin
It also uses fing info. Gives up/down/expired status for Ip devices
