Smartphone radar always goes to device away status
Mon Apr 14, 2014 7:31 am
captcurrent offline
Love the plugin... You did a great job on your installation guide even providing great links to get the syslog working
I think I may be missing something on the away feature
The way I read it and from my limited experience to date The smartphone status goes "away" automatically after the interval set in the configuration
This is probably a result that I imagine the syslog doesn't show the phone dropping its connection to the wifi
this in my use results in either a quick change to away status or a slow change when I actually physically leave
the best option i can come up is creating a script to ping the IP and keep they status at home when it is fact home....
is thee something simpler I am missing ? any help would be appreciated
Mon Apr 14, 2014 10:11 am
Dewster35 offline
Re: Smartphone radar always goes to device away status
Try iTunes wireless syncing for the device and keep iTunes open.
Mon Apr 14, 2014 10:25 am
captcurrent offline
I am using an android smart phone.... I have been kind of backing away from Mac IOS thanks for the response though
What i threw together was the following applescript
set IP_address to "10.0.1.51"
try
   set ping to (do shell script "ping -c 2 " & IP_address)
   log "good"
   using terms from application "IndigoServer"
         set value of variable "DroidHome" to "true"
         set value of variable "AllPhonesAway" to "false"
      end tell
   end using terms from
on error
         set value of variable "DroidHome" to "false"
         set value of variable "AllPhonesHome" to "false"
      end tell
end try
This took care of the problem in a non-graceful manner
what is strange is that Indigo 6 will only run it as an embedded script not as an attachment
Wed Apr 16, 2014 10:39 am
captcurrent offline
found that script didn't always works
but this topic viewtopic.php?f=4&t=8664&hilit=ping+command
pervaded a solution to the ping issue
