Aeon Labs Key Fob Remote (DSA22)
Wed May 20, 2015 3:32 pm
2903NY offline
Re: Aeon Labs Key Fob Remote (DSA22)
I had some trouble getting my key fob to join my z-wave network, but after a new battery, I was about to join and synce it. I set the buttons to scene control (which is reflected in the sync data). But I get no response in the event log to any key press or hold. I have included the sync log and device dump.
May 20, 2015, 5:25:19 PM
Z-Wave Syncing - started for device "029 - Key Fob (ZW088)"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Key Fob (ZW088) - 01010058
Z-Wave Syncing - retrieved protocol version 3.83, app version 1.02
Z-Wave Syncing - retrieved class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "029 - Key Fob (ZW088)" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved Enable scene mode for all buttons is true
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave received "029 - Key Fob (ZW088)" status update battery level 100%
Z-Wave Indigo Device "029 - Key Fob (ZW088)" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.350
Node ID: 29
Model: Key Fob (ZW088)
Model ID: 01010058
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.83
Application Version: 1.02
Model Definition Version: 3
Library Type: 2
Class Name: Portable Remote Controller
Class Hierarchy: 01 : 01 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 5Av1 5Ev1
Features: battery, beaming, waking
Neighbors: - none -
Associations: 1:[1]
Config Values: 250:1
Thoughts?
Thank you,
-Scott (2903NY)
Fri May 22, 2015 1:40 pm
Hi Scott,
I'm not sure what is wrong. Your Event Log and configuration settings look correct. Some things to try:
1) Exclude the module from the Z-Stick, then re-include it (then re-Define/Sync it in Indigo).
2) Toggle the Enable scene mode for all buttons checkbox OFF, save the settings (while keeping the keyfob awake), then repeat but re-enable the checkbox.
3) Turn on debug logging for Z-Wave via the Interfaces->Z-Wave->Configure... menu item, then try pressing the buttons. Is nothing still logged?
Sat Dec 12, 2015 3:44 pm
erikwegman offline
I just synced my Key Fob to indigo and the event log shows that button signals are coming in. So far so good. There is just no button to configure. How and/or where can I configure the buttons?
Schermafbeelding 2015-12-12 om 22.43.18.png (34.59 KiB) Viewed 7877 times
Schermafbeelding 2015-12-12 om 22.42.11.png (36.38 KiB) Viewed 7877 times
Sun Dec 13, 2015 8:17 am
colin_d offline
Mine is not a recent version DSA22 but this worked for me:
In the 'Type' dropdown select 'Z-Wave Event' instead of 'Device State Changed'
Then select 'Z-Wave Command' underneath
In the pop-up window choose your device and then the relevant triggers will be available in the 'Received' field.
Hope that helps
Mon Dec 14, 2015 2:30 pm
erikwegman offline
Yep, this worked!
Thu Feb 11, 2016 3:39 am
kwijibo007 offline
Hi Matt & Jay,
I just got a DSA22 (Gen5), all synced and I have the correct responses in the event log when I press a button. The issue I have is that I don't get the individual buttons as options under the trigger (Z-Wave Event-> Z-Wave Command). A you can see below I only get the battery level and any command
Ive re-defined & synced many times with no luck.
Below is one of the key presses and a define & sync in the log
11 Feb 2016, 8:10:16 PM
  Z-Wave                          received "Keyfob - Pete" scene 2
  Z-Wave                          Syncing - started for device "Keyfob - Pete"
  Z-Wave                          Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Portable Remote Controller - 02010058
  Z-Wave                          Syncing - device "028 - Keyfob - Pete" wake interval changed to 60 minutes
  Z-Wave                          received "028 - Keyfob - Pete" status update battery level 100%
Any ideas?
Pete
Tue Feb 16, 2016 9:35 am
Hi Pete,
Your key fob has a new model ID Indigo does not yet recognize. We'll get it added to the next bug-fix release of Indigo 6.1 for you.
Tue Feb 16, 2016 3:48 pm
kwijibo007 offline
That's great, thanks Matt.
Tue Mar 08, 2016 6:56 pm
Indigo v6.1.7 is now available and includes the model ID for the key fob you have.
Wed Mar 09, 2016 1:11 am
kwijibo007 offline
I've tested and it works perfectly. Thanks for your help.
Pete
Mon Nov 07, 2016 11:11 am
haavarda offline
I have just revcieved a version of this Key Fob. Gen 5. I dont get any response when I press any of the buttons, but it is successfully included, and I am able to sync it.
Is it a new device definition case?
Indigo Z-Wave Version: 1.0.371
Node ID: 110
Model ID: 00010058
Application Version: 1.03
Library Type: 2
Neighbors: - none -
Associations: 1:[1]
Håvard
Mon Nov 07, 2016 11:16 am
haavarda offline
Sorry.
I just had to exit setup mode on the key fob. It is working perfect now.
Håvard
Mon Nov 07, 2016 2:49 pm
kwijibo007 offline
Is anyone else getting terrible battery life on these key fobs? I've got 5 units and I'm lucky to get a month out of fresh batteries.
I've got a mix of both 1 button / 4 button / Gen 5 and the older model.
Pete
Thu Dec 01, 2016 4:56 pm
colin_d offline
Pete
I've got a 1 button DSA38 and also a 4 button DSA22, not Gen 5 though.
I tweaked the wakeup interval to once a week and I'm getting over six months out of mine.
It will depend on usage, I guess I use both units up to 4 times a day.
The battery level doesn't mean much on these, they seem to give a stable voltage throughout most of their life but can then die quite suddenly.
Keep a couple of spares!
I prefer the Minimote now as its rechargeable :)
Hope that helps...
Colin
Fri Dec 02, 2016 2:27 am
PeteVis offline
I have the ZW088, which is the Gen5 model if I'm not mistaken.
Battery life for me is also more or less a month. I haven't tried to set the wake interval to a week, I should try that, but for the moment I am using the Octan remote.
The Octan is nice, but I don't really like the tactile feel of the buttons... that means, there is no clicky button action at all.
Other than that, it seems the batteries are holding up better than the Aeon keyfob.
