Insteon Fanlinc with Casablanca Inteli-Touch Fan
Sat Feb 25, 2012 1:03 pm
bbruck offline
I have a Casablanca Inteli-Touch fan that I want to use with an Insteon Fanlinc.
I have disassembled the fan and can see the wires as shown on page 6 of the attached wiring diagram. Attaching the Fanlinc wires to the white and black for the fan's light kit is pretty straight forward, as is attaching the Fanlinc power wires.
The three remaining wires are a little bit of mystery to me. The diagram (see attached pdf) shows the following:
Red --|
| 60 Ohm
White-| 120 Ohm
| 60 Ohm
Brown-|
I'm guessing that I either need to select one of the red or brown and the white to attach to the Fanlinc (where the other one would have the fan going the opposite way) OR that these are used in combination with the triacs to give 3 of the six speed settings and that my only option is to pick the red OR the brown to attach to teh Fanlinc in combination with the white.
I'm hoping that someone with a smidge of electrical experience might be willing to look at this and give me a hint as to how to proceed.
(I'm also assuming that no matter what I do, I'll lose the ability to ever reverse the fan, but am willing to accept that price to control it with Indigo.)
Fan wiring diagram
Casablanca wiring diagram.jpg (287.38 KiB) Viewed 8532 times
Sat Feb 25, 2012 1:04 pm
bbruck offline
Re: Insteon Fanlinc with Casablanca Inteli-Touch Fan
The text below the diagram says the following:
The microcomputer sends commands to the light drive
module, (LDM), which in turn controls the on/off and dimming
range of the light fixture. Note: The microcomputer “reads” the
presence of the LDM by detecting the operation of a small light
emitting diode within the optocoupler on the LDM.
The microcomputer also controls the direction of the fan
through a small reversing relay mounted on the
RMM circuit board.
To control motor speed, the microcomputer selects one of
six outputs, each of which turns on an electronic switch known
as a triac. These six triacs are located on the RMM circuit board.
In high speed, a triac drives the motor directly. In all other
speeds, a triac drives the motor through one or all five dropping
resistors contained within the BFR. This reduces power to the
motor while maintaining a pure sine wave drive.
Thu Apr 05, 2012 7:43 pm
By the way, Indigo 5.1.0 is available and has support for the FanLinc. Documentation to explain how it works will be forthcoming.
Mon Apr 17, 2023 5:05 pm
2013automator offline
Jay since you're a FanLinc user I'm hoping you can help shed light.
I want to control my Casablanca Inteli-Touch Fan using Indigo. I'm willing to replace the electronics if needed.
It's an older model from about 2010 (model #3232T, named "Stealth") with an AC motor.
Here's the tech specs: https://s3-us-west-2.amazonaws.com/valu ... P32-48.pdf
How do you wire the FanLinc to this?
Specifically, do I replace the factory fan controller (the RMM PC board and/or the BFR fan speed controller) and wire the FanLinc directly to the AC motor?
Or does the FanLinc require a controller board between it and the motor?
Or does it go FanLinc -> Capacitor -> AC Fan Motor?
What other alternatives are there to FanLinc if I want to not be beholden to Insteon long term?
One potential option would require an Indigo plugin (right?) to connect with this replacement controller from Fan Man:
https://fanmanlighting.com/shop/new-rep ... h-century/
FanMan Lighting says this replacement board connects via bluetooth to the Fanimation FanSync smart phone app, which I guess is here https://fanimation.com/fansync/
Mon Apr 17, 2023 5:53 pm
That's a question best asked of the Insteon team.
In terms of alternatives, we support the Z-Wave Fan Controllers (though they present as dimmers in Indigo, they will work). You can also check the plugin store for other alternatives.
Mon Apr 17, 2023 9:43 pm
Hi Jay,
I know you are the software guy not the hardware manufacturer, but since you personally have 3 or 4 FanLincs set up, I was wondering if maybe you could share your experience with how you wired yours ?
Tue Apr 18, 2023 8:22 am
Note the date on my post; it was 11 years ago (you sorta brought this topic back from the dead :D ). I haven't personally used FanLincs in years. I don't recall doing anything other than following the instructions that came with the FanLinc.
