x10 HR12A and 2413U issue
Sun Dec 04, 2011 4:56 pm
carmanah offline
I have recently switched from Active Home Pro using a CM15 to Indigo 5 using a 2413U. I am still using all my X10 switch modules etc. The change went pretty well but I can't seem to get my HR12A Palm Pad to work. I can control everything from my Mac and also from my iPad using Indigo Touch but I'd also like to use the Palm Pad. I missing something in the setup?
Sun Dec 04, 2011 5:33 pm
Re: x10 HR12A and 2413U issue
The 2413 doesn't do X10 RF so you'll need some kind of X10 RF receiver - a W800USB, an MR26, or even a little TM751 if it's only a single PalmPad and you can locate it close to where you use it. If you're planning on converting to INSTEON the latter is probabaly the cheaper idea.
Users browsing this forum: No registered users and 34 guests
