Thermostat Wiring Question
Posted: Sat Oct 22, 2011 8:34 am
First let me apologize... Doing a search indicates that the answer is probably already posted, but reading through a lot of the info I was getting confused so I thought it best to ask in a new thread:
I purchased a home and am getting all of my equipment set back up to be controlled by Indigo. The one "hiccup" I'm having is figuring out the thermostat in the new place, and I think it just comes from a lack of knowledge of HVAC systems in general. I have the Venstar T1700 and the T1900, but I have not been able to decode the existing thermostat's connections to know exactly how to hook either up. This is what is currently in place:
R (connected to a red wire)
G (connected to a green wire)
O (connected to an orange wire)
Y (connected to a yellow wire)
E (connected to a white wire)
My understanding, then, is that R is the power, G controls the fan, O controls the reversing valve (?), Y controls the emergency heat (?), and white is, perhaps, common (?).
When I hooked up the T1900 according to the above idea I never received anything on the display, as though the thermostat was not receiving any power. I did not try hooking up the T1700 because it was still packed away.
My question, then, becomes more of a guide for what I should be hooking up. Does anyone have any experience with five wire systems and the corresponding setup on the Venstar units? Should I, perhaps, be adjusting the jumpers as well?
Attached is a picture of the existing wiring to the existing thermostat.
