I'm trying to transition off an old serial X10 control tethered to a linux box to Indigo on my dual g4 workstation with a 1132CU usb interface. The old X10 interface works great and is 99% reliable. When we moved into our new house 3 years ago, I had trouble with signals reaching both legs of our house's wiring. I installed a repeater in the breaker box and that solved all the problems.
However, with the new 1132CU, I can't get very good performance at all. Here's my test case. I have two lamps set to the same housecode/number. One is in another room on the other end of the house. One is in the room with the mac and 1132CU. Using the 1132CU to issue commands, only the lamp in the same room responds. Using an X10 remote (and receiver in a third room), both lamps respond to all commands.
The 1132CU is plugged into the wall outlet and a UPS for the Mac is plugged into the 1132CU. Could it be sucking up the signal, making it too weak to propagate to the rest of the house (but still strong enough to trigger the lamp box in the same room)? Should I use a filter between the 1132CU and the UPS? I was thinking of trying the filterlinc (http://www.smarthome.com/1626.html) -- might that solve the problem?
I'm really looking forward to moving to Indigo. My old setup was pretty braindead with simple hard-coded on/off scheduling for lights. Building smarter responses with triggers and sunrise/sunset timings looks great, but I'm pretty much dead in the water until I can get this 1132CU working reliably.
thanks,
jay
